Power FC help!
Old Aug 25, 2004 | 11:11 PM
xxfetusmanusxx's Avatar
ricankilla!
help!
need to cut down my fuel by 1/2 on my first 3k, its running REALLY rich and i need to know in what section of the pfc commander i can find it.
also can anyone recomend a good wideban o2 sensor?
Old Aug 26, 2004 | 03:17 AM
twokrx7's Avatar
Need more sleep
setting - Pim Volt - 1. Normal - there are two tables you can change, fuel by PIM voltage range (i.e. boost) or fuel by rpm band. Refer to pg 24 in the manual. Easy to f**k up here so be sure you know what you are doing, manual is an easy read.
A little advice, better put your flame suit on asking such a simple question that has been discussed so many times, some folks are not very nice if it appears you have not done any homework before asking. I only answered because I was bored and could not sleep.
Old Aug 26, 2004 | 12:58 PM
ricankilla!
thanx man! when i go under the settings, injectors, the fr-pr doesnt change the cars behavioar... evein if i put it at 25% .... is this wierd?????
Old Aug 26, 2004 | 05:39 PM
cewrx7r1's Avatar
Eye In The Sky
This question cold have been easily found in the user manual.
You do read don't you?
Old Aug 26, 2004 | 06:04 PM
ricankilla!
i dont have the damn thing!! thanx!! if u took the time to write crap like that u could of just anwser the question...
Old Aug 26, 2004 | 06:20 PM
ricankilla!
sorry for the last post.... im emotionally drained with this thing
Old Aug 27, 2004 | 10:05 AM
cewrx7r1's Avatar
Eye In The Sky
I am emotionally drained by people who have equipment and no manuals for it, or do not read them.
Old Aug 27, 2004 | 12:29 PM
ricankilla!
and again! dick comes out!
Old Aug 27, 2004 | 01:42 PM
RotorJoe's Avatar
Hooray For Boobies!!!
You can also set it up to do a map trace. Drive the car how you normally do and how you do when it is running rich from 1000-3000RPMs. Then look at the map trace and see what cells you are using. Do this a few time to see exactly whats going on and the cells you normally run in. From there start pulling fuel out of those cells. However a wide band would help a great deal in this area.
Otherwise pull from the PIM RPM range, but beware. You need a wideband.
Oh yeah, this is the wide band I use.
http://www.innovatemotorsports.com/
I like it and it works well for me. I have hear of others that do not measure below 11.0-1 fuel ratios. This one goes all the way to 10.0:1, probably lower but that is what I run under boost for the most part.
Good Luck, tune slow, very slow.
