Question About performance?
Old Aug 24, 2004 | 03:30 PM
RX7Vegeta's Avatar
Question Question About performance?
Own a 1984 GS putting performance air cleaner on capped all vacum lines what should i do with the air pump hose and other air hoses?
Old Aug 24, 2004 | 04:06 PM
RX7Vegeta's Avatar
You can't cap the lines i was wondering if I should put Breather filters in them? What do you guy's thin I should do?
Old Aug 24, 2004 | 04:35 PM
RX7Vegeta's Avatar
So Nobody in here knows what to do with this or what?
Old Aug 24, 2004 | 04:51 PM
nevarmore's Avatar
You shouldnt just cap those lines. They need to breathe clean, filtered air. You should either tap fittings into your new air cleaner or make a seperate breather for them.
Old Aug 24, 2004 | 05:01 PM
RX7Vegeta's Avatar
what would u personaly recomend nevarmore?
Old Aug 24, 2004 | 06:02 PM
vipernicus42's Avatar
Rotoholic Moderookie
Rx7Vegeta, you're not off to the best start. PLEASE don't make two threads for the exact same topic, and have patience. Just because people don't post within an hour doesn't mean that nobody knows your problem. Some people on here only check in once a day!
Now I'm getting curious. When you say you capped off "all vacuum lines", do you just mean the ones that went to the old airbox, or ALL vacuum lines from the carb?
my questions from the other thread stand: do you have cats or need to pass emissions?
If you don't, then follow the emissions removal tutorial that Rx7Carl and Pratch wrote, and it should help solve the problem. You can't just randomly cap a few lines and expect things to work.
Sorry to come down so hard, but you've got 5 posts already to ask one question. My suggestion: grab and follow the rat's nest removal tutorial and you won't have to worry about it. It's in the FAQ
Jon
Old Aug 25, 2004 | 09:41 AM
nevarmore's Avatar
Do what he said, word for word thats what I'd suggest you do as well.
Old Aug 25, 2004 | 03:08 PM
RX7Vegeta's Avatar
Thanx for the info I'm actually new to the system and a new RX-7 owner always been in love with the cars finally got off my but and got one, just as another question will removing the rats nest help with performance at all? Don't worry I will be pulling up the FAQ page.
Thanx again for the info and sorry about the double post.
Old Aug 25, 2004 | 04:08 PM
IanS's Avatar
Ricer
Removing rats nest wont gain performance, but it will make it easier to troubleshoot any possible vacuum leak in the future.
Old Aug 25, 2004 | 04:25 PM
slashdawg00110's Avatar
RTFFAQ
Exactly. And it makes for a less-cluttered engine bay. Of course, you lose the opportunity to make a color statement with several feet of colored vacuum hose.
Jon's right. Only post your question once. If you like, you can post the same question at a few different boards: www.mazspeed.com and www.nopistons.com are a couple alternatives. With any luck, the answers will be the same.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
