Weird squeaking noise in reverse?!?!
Old Nov 22, 2001 | 02:59 PM
virtego13's Avatar
my car makes a wierd "sqeaky - sqeaky" noise when backing up. The sound gets progressivly faster as I accelerate (in reverse). Since it only does it in reverse, I assume it is in the tranny. Any suggestions or ideas?
THANX!
-k
Old Nov 22, 2001 | 06:30 PM
skibum9199's Avatar
college student
My brakes squeak horribly in reverse if i stop.... maybe your brakes are doing the same, but the pads are too close to the rotor so are practially touching at all times. Just a thought before you go buy a new tranny
~Jesse
Old Nov 23, 2001 | 02:28 PM
virtego13's Avatar
no... it is definately not the brakes. it is not that kind of squeaking. it almost sounds like the creaky door in all those corny horror movies. ya... that is almost exactly what it sounds like.
any more ideas?
Old Nov 23, 2001 | 02:29 PM
virtego13's Avatar
oh yeah... and it does it even when i am not stopping... it'll do it if i don't even have my foot on the brake pedal. trust me... not the brakes.
Old Nov 23, 2001 | 02:57 PM
HAILERS's Avatar
HAILERS
Brakes. Application not required.
Old Nov 23, 2001 | 03:39 PM
Scott 89t2's Avatar
SOLD THE RX-7!
they could be comming from anywhere... I say get someone to lay on the ground beside the car (not behind... ) and listen as you back up to at least get the gerneral area if you can't figure it out.
Old Nov 25, 2001 | 01:04 PM
virtego13's Avatar
ok guys... you'll just have to trust me on this one, ITS NOT THE BRAKES! if you heard it you would know right then that its not. also, after listening to it from outside the car, i have pinpointed it in the general area of the driveshaft and transmission. i am really stumped on this one... i don't know where to start.
Old Nov 25, 2001 | 01:30 PM
rico05's Avatar
WTB S5 N/A FC
I have the same problem! Hope someone can help ya man!!!
Old Nov 25, 2001 | 10:43 PM
skibum9199's Avatar
college student
Hmmmm... maybe bad differential mounts? Or something loose thereabouts? Maybe just squeaky tranny or differential mounts.... I heard that the early polyurethane bushings(aftermarket) would squeak like hell... now they are graphite impregnated. Get under your car and check it out.. anything loose or just look not right(or wrong, lol)?
~Jesse
hailers?
Old Nov 27, 2001 | 02:10 AM
rxspeed87's Avatar
mine did that also
then after about 2000 miles I broke the tranny housing and driveshaft
LongDuck
Oct 7, 2015 08:12 PM
manoflego
19
Sep 30, 2015 05:19 AM
Devon Murray
Sep 26, 2015 08:15 AM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
