Smitomo HTR 200's 500 mile test
Old Aug 21, 2004 | 11:46 AM
Rx7carl's Avatar
Airflow is my life
Well theyve been on the car car for about 500 miles. Nothing but good things to say about them. They handle well wet or dry, arent real noisy, have good road feel. The ones I have are 215/50/13 on stock rims. Only problem is I did get a flat yesterday (lotsa debris around here) and the jack wouldnt fit under the car on the pinch weld. I also have ST springs on the car. I had to lift the car about 1/2" and kick the jack into place. Quite a feat of coordination.
Old Aug 21, 2004 | 12:44 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Thanks for the info. I've been thinking of getting a set in 185/60/13 for my second Fiesta. I have a friend who can get them for about $40 each with no shipping.
Old Aug 21, 2004 | 12:48 PM
bouis's Avatar
215s on the stock wheels... no wonder one went flat. Heh.
I just got a set of 185 Yokohama Avid T4s, and I give them the thumbs up also. Probably not as good for traction but I'll bet they feel a lot more "crisp."
Old Aug 21, 2004 | 01:20 PM
diabolical1's Avatar
this is good news. i just bought two 205/60's for the rear of my car. i'm waiting for delivery and can't wait to get the car back on the road.
Rx7Carl~ you got any pics of your car?
Old Aug 21, 2004 | 05:16 PM
brandon davis's Avatar
those tires are on the stock cross rims? i sm considering some tires for my stock wheels but have to ear these out first.
Old Aug 21, 2004 | 05:40 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
See Carl? I told you
I'm on my second set of those tires, exact same size, very satisfied with them.
Old Aug 21, 2004 | 07:24 PM
slashdawg00110's Avatar
RTFFAQ
OK, I've heard enough. These are the tires I'm going to get.
Old Aug 21, 2004 | 08:10 PM
Rx7carl's Avatar
Airflow is my life
I ran over a bolt, thats what caused teh flat. I ran that same size years ago with the BFG TA tires without any problems. Yes thats on the stock cross wheels. No pics, but I can take some.
Old Aug 21, 2004 | 10:00 PM
Kentetsu's Avatar
No problem with clearances using that size tire on a stock setup? Looking for some new rubber to replace the 4 snow tires I currently have on (don't yell at me, I bought it that way!).
Old Aug 21, 2004 | 10:12 PM
cdrad51's Avatar
Oh yeah good point. Do you rub anywhere at all Carl? I have 10 mm spacers on to be able to have that width tires without rubbing anywhere. Or is it 5 mm? I can't remember.
Old Aug 21, 2004 | 11:14 PM
werd's Avatar
gslse sumos
I just got a set of 205/60/14 htr 200s for my gslse. Good tires so far though, i should have gotten a little wider and and lower profile size. i was worried that they might rub. They hook up really good, i can drop the clutch at 5000 rpm without much wheel spin at all. Does anyone know if wider/lower profile tires would rub?
Old Aug 21, 2004 | 11:16 PM
eddierotary's Avatar
back with rotaries
i have the same ones on my car, and they are good, the only thing that bother me that have soft sidewall and you could feel the tire roll on a autoX pretty good
Old Aug 21, 2004 | 11:24 PM
werd's Avatar
Ive noticed that they roll pretty easily too, i though it might just be me though.
Old Aug 22, 2004 | 12:40 AM
that would be awesome! i just want to see how the car sits with the suspension and tires. i thought about going with 215/50, but i figured it might not sit well.
Old Aug 22, 2004 | 12:48 AM
1stgen4life's Avatar
Leaking oil like crazy!
My HTR 200s are hopefully on their way to Big-O-Tires right now. I ordered them and can't wait. I'm getting 205-60-13s for my stock rims. I'm glad to hear the good things.
Old Aug 22, 2004 | 02:39 AM
Rotor13B's Avatar
Wassup!!
That's because you guys are running them on the stock rim.
Old Aug 22, 2004 | 12:38 PM
cdrad51's Avatar
Truly a weakness of this tire. I try to compensate by keeping the pressure at just under 50 psi.
Old Aug 22, 2004 | 05:51 PM
Rx7carl's Avatar
Airflow is my life
Yea I did notice a little flexing. But I know Im running a little too low on the pressures so I plan to bump them up a little at a time till Im really happy. The nice thing is that even though the sidewall is soft, on a 50 series tire its really short so it shouldnt be that bad one the pressures are right. I'll snap a pic after I get the spare off. Its making the car sit lopsided.
Oh and no rubbing so far. Stock struts (no coilovers).
efini7
Test Area 51
Sep 4, 2015 02:59 AM
