Idle
Old Aug 20, 2004 | 04:41 PM
U.S.ARMY's Avatar
Idle
what should my rpm's be while ideling?
Old Aug 20, 2004 | 04:46 PM
U.S.ARMY's Avatar
let me explain what the problem is. when it's ideling it seems like it wants to die, but it don't. i don't know if it's the timing, the idle needs to be adjusted or what. and ideas of what could be the problem?
Old Aug 20, 2004 | 04:57 PM
RotaryRyan's Avatar
DSM
I idle my car at 1000rpms. It should idle at 750rpms. you can check for a vac leak. check the timing too. i thought mine was right for a long time then found out it was way off.
Old Aug 20, 2004 | 04:59 PM
RotaryRyan's Avatar
DSM
I think i remember your car being carbed. Right??? could be the idle mixture??? BUT i would try the other stuff first.
Old Aug 20, 2004 | 05:04 PM
U.S.ARMY's Avatar
yeah it's carbed, how do i check the timing? lol
Old Aug 20, 2004 | 05:09 PM
RotaryRyan's Avatar
DSM
get a timing light. do you have one?
Old Aug 20, 2004 | 05:12 PM
U.S.ARMY's Avatar
yeah
Old Aug 20, 2004 | 05:35 PM
U.S.ARMY's Avatar
and how exactly do i set my idle to 1000rpms?
Old Aug 20, 2004 | 05:49 PM
U.S.ARMY's Avatar
do i adjust to idle air screw or mixture screw?
Old Aug 20, 2004 | 06:05 PM
U.S.ARMY's Avatar
alrighty, i'll just go find out. lol
Old Aug 20, 2004 | 06:11 PM
RotaryRyan's Avatar
DSM
you adjust the idle SPEED screw. Its a bit harder to find. Ill see if i can find a pic but its right near the throttle linkage.
Old Aug 20, 2004 | 06:30 PM
U.S.ARMY's Avatar
thanks
Old Aug 20, 2004 | 06:36 PM
U.S.ARMY's Avatar
and my accellerator pump is leaking, could this have somethin to do with it?
Old Aug 20, 2004 | 06:48 PM
lovintha7's Avatar
Suicidal Death Missile
yea, it's prolly suckin air, and leaning it out
replace that, then see where it idles
Old Aug 20, 2004 | 06:58 PM
U.S.ARMY's Avatar
ok thanks.
Old Aug 20, 2004 | 09:19 PM
Rx7carl's Avatar
Airflow is my life
No, the accel pump wont suck extra air in. But if its leaking, you should replace it. What year US Army? Theres 2 flavors of carbs which idle adj is different for each. Yea it does sound like you have a vacuum leak.
Old Aug 21, 2004 | 12:31 AM
U.S.ARMY's Avatar
it's an 84. i read on here somewhere i just spray wd 40 on the hoses and if it revs up the leaks somewhere around there?
Old Aug 21, 2004 | 12:46 AM
RotaryRyan's Avatar
DSM
ive heard carb cleaner. WD-40 might work. ive never used either of these methods. I guess im luckky
Old Aug 21, 2004 | 06:11 AM
Rx7carl's Avatar
Airflow is my life
Idle speed adj for you is the screw aft of the accel pump. Its kinda buried and hard to see.
Old Aug 21, 2004 | 06:25 AM
inittab's Avatar
I read your email
In the FAQ there's a ton of info that you might find helpful
Q. I'm having trouble with my Nikki carburetor, what should I look for?
A. Sterling has written some excellent articles on the subject, check them out.
Carburetor Troubleshooting- Flooding Problems
Carburetor Troubleshooting- Acceleration Problems
Carburetor Troubleshooting- High RPM Power Loss
Nikki Carburetor Rebuilding Tips
Leave yer damn Float Levels ALONE!...
How to adjust the idle on a Nikki carb
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
