tuned my setup 5psi
Old Aug 15, 2004 | 04:01 PM
XSTransAm's Avatar
Ee / Cpe
Talking tuned my setup 5psi
it went BAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
but yeah, i tuned it up for 5 psi this morning, it feels almost as fast at 5 psi as my stock twins did at 13. Then the wastegate opens up and it makes the coolest sound ive ever heard! the gf says it sounds like a racecar, i was like DUH!
cant wait to hit 15psi on the dyno this week!
Old Aug 15, 2004 | 07:58 PM
Wargasm's Avatar
Weird Cat Man
MUAHAHAH!!!!
I want that dyno!!!!!!!!!
Old Aug 15, 2004 | 09:50 PM
XSTransAm's Avatar
Ee / Cpe
Originally Posted by Wargasm
MUAHAHAH!!!!
huh?
Old Aug 16, 2004 | 06:33 AM
Wargasm's Avatar
Weird Cat Man
I'm excited about seeing your dyno is all...
Old Aug 16, 2004 | 08:49 AM
XSTransAm's Avatar
Ee / Cpe
oh ok :P me too
Old Aug 19, 2004 | 08:34 AM
XSTransAm's Avatar
Ee / Cpe
stuck it on the dyno last night, unfortunatly it was misfiring around 5500 and i couldent get a full run in, so no boost for me
I hate how quick these engines burn plugs.
Old Aug 19, 2004 | 06:09 PM
zayrx7's Avatar
the mazda zoom zoom store
how much boost were you running
Old Aug 19, 2004 | 06:49 PM
Wargasm's Avatar
Weird Cat Man
On my car, I get good results running 9s for the leading and BR10EIX for the trailings... Four of the 9s also worked pretty well. If you're fouling plugs with one of the two setups I just mentioned, I'd suspect the AFR is about 9.5:1
Brian
Old Aug 20, 2004 | 12:00 PM
apneablue's Avatar
When I heard the WG open on mine for the first time i smiled so big the corners of my mouth met at the back of my head...It's really great..
I am running the Gt35r and steve was tuning to 17psi but we have to leave it at 15 because of ignition breakup...I'm still running the stock ignition...Figure will have to upgrade that before I go any higher...What's your ignition setup?
Old Aug 20, 2004 | 12:35 PM
SlingShotRX7's Avatar
XS,
So you tune yourself??
Cool.., I take you have a Wideband and Dataloggit.
Still waiting to tune my FD
Old Aug 20, 2004 | 12:55 PM
artguy's Avatar
WTB** Very Low Miles 94-95
my wastegate vents to atmosphere and its just way to obnoxious....the only time i enjoyed it was when i kicked it down next to a whole pack of parking ricers....everyone of them nearly **** themselves.
j
Old Aug 20, 2004 | 05:35 PM
1RevvinFC3S's Avatar
DOWNSTAIRS MIXUP
Hey artguy, how much for the twins (if you are talking about your stock turbos that is ).
Old Aug 21, 2004 | 01:48 PM
XSTransAm's Avatar
Ee / Cpe
yeah i tune it myself, ive got a completely stock ignition... however i do have a t2 leading coil sitting on a shelf. after i change out my plugs i will try the coil if the problem isnt fixed.
Old Aug 22, 2004 | 04:08 PM
radkins's Avatar
How do you get only 5psi? The lowest I can go is 10psi What turbo is it?
Old Aug 22, 2004 | 05:28 PM
XSTransAm's Avatar
Ee / Cpe
its a t61, im running the lowest psi spring in my wastegate available....
its creeping up the whole way though, its probably around 7psi by like 8k.
Old Aug 22, 2004 | 08:37 PM
arowell351's Avatar
Turbo lag?????
Hey man.... Just interested to know, you said the power from the tuned 5-7psi feels the same as 13psi on the factory twins...... Is the car far less responsive???? i would expect it should be...but not sure... whats the situation..
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
msilvia
15
Sep 11, 2015 12:13 PM
