in need of cooling system help!
Old Aug 14, 2004 | 03:15 PM
kuruptONE's Avatar
hi, i just got my 1993 rx-7 early july and it runs fine and everything, but eversince i got this car i've had a small coolant leak. it's not coming from the radiator, but a connection that is located below left of of a sensor sender (not sure what sensor is, but the sensor is directly below the oil filter) and it's to the right of the leading and trailing plugs. you will know what i am talking about if you are looking down from the driver's side fender with the intake elbow off. anyways i thought the coolant hose was cracked due to how old it was so i removed it and found out it wasn't it either. i found out that there was a crack on the connection end and whenever coolant was running thru it, small amounts (like little drips off a leaky faucet). so i need some one's help identifying the part and how to replace it. i also need the part number if you know it. thanks in advance.
you can find pictures of what i am talking about on yahoo photos
http://f2.pg.photos.yahoo.com/kayarpi
look under "1993 rx-7"
keith
Old Aug 14, 2004 | 03:26 PM
KaiFD3S's Avatar
SINFUL7
all I see is a subaru in your album
Old Aug 14, 2004 | 03:46 PM
mad_7tist's Avatar
if it is the quick disconnect hose you can cut off the plastic fitting and put a hose clamp over the rubber coolant line.
Old Aug 14, 2004 | 05:49 PM
kuruptONE's Avatar
oops... check it again. i forgot to switch the album to public.
Old Aug 14, 2004 | 08:08 PM
kuruptONE's Avatar
ttt
Old Aug 14, 2004 | 09:24 PM
wrankin's Avatar
Old Rotary Dog
It's actually more of a "quick connect" than "disconnect". It's supposedly used at the factory to facilitate hooking the engine up. It's a frequent point of failure and shoudl be removed.
To do this remove the hose and then remove the quick connect from the block connection (difficult to do - I had to delicately cut mine off). Then just reclamp the host to the remaining nipple.
Good luck,
-bill
Old Aug 14, 2004 | 09:28 PM
kuruptONE's Avatar
thank you very much... your help was greatly appreciated.
Old Aug 14, 2004 | 09:51 PM
kuruptONE's Avatar
how do you remove the quick connect part?
Ian_D
Oct 14, 2015 12:31 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
