Does this make sense???
Old Aug 12, 2004 | 07:18 PM
Quadulus's Avatar
My CEL is on.. I find a code 16 which is EGR. I reset the computer by doing the negative battery/hold brake trick. Next I reconnect the cable and check the codes again. Still getting a code 16. Why is that? I thought the car needed to run a bit before it would give me another error code. I disconnected the cable from the EGR and got the same result. Does this mean my EGR solenoid is hosed?
Old Aug 12, 2004 | 08:12 PM
legal-z's Avatar
12th son of the lama
i would check the connection first. it's a blue plug in front of the uim on the passenger side. it's buried down in there so you have to take a good look. mine comes loose occasionally and causes the same thing.
Old Aug 12, 2004 | 08:49 PM
Quadulus's Avatar
It was connected while getting this code... then I tried disconnecting it and resetting it.. still getting the error code. I get it hooked up or unhooked even without starting the car. And I reset the computer between tests.
Old Aug 13, 2004 | 04:31 AM
scotty305's Avatar
~17 MPG
Might also want to perform the EGR valve test, to ensure that your EGR system is functioning properly:
http://www.scuderiaciriani.com/rx7/EGR_valve_test.html
Assuming everything's gravy, you might look into...
EGR switch bypass: the EGR switch is the sensor that causes a check engine light when it doesn't detect the EGR valve opening and closing. This sensor tends to fail from heat.
https://www.rx7club.com/forum/showth...threadid=21848
https://www.rx7club.com/showthread.p...threadid=67757
https://www.rx7club.com/showthread.p...hreadid=209485
Old Aug 13, 2004 | 06:13 AM
Quadulus's Avatar
Sweet.. off to radio shack I go!
jsesq
27
Sep 25, 2015 11:10 AM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
