Where do you keep your fire extinguisher?
Old Jul 31, 2004 | 10:19 PM
Syonyk's Avatar
I figured this would be most relevant here.
Where do you have your fire extinguisher mounted for normal driving? I have a wonderful little unit that I have attached to the carpet of the passenger's side stuff-box, except it tends to fly off and roll around the back after a hard corner or start or such. The velcro stays attached to the carpet, but the rest of the holder falls apart. I'm going to epoxy it here soon, but it raised a question: Where do other people keep them? Bins make sense, but are a bit slow to get at when needed.
-=Russ=-
Old Aug 1, 2004 | 12:15 AM
diabolical1's Avatar
that's where i keep mine. what you said is true, it does present a few extra seconds of fiddling with the seat and cover, but i keep it there simply because when i park my car i hate to have anything is plain view for some dickless piece of crackhead **** to think "easy score". sorry, just brought back bitter memories ...
Old Aug 2, 2004 | 01:47 AM
cruiser's Avatar
In the passenger bin behind the seat. Works well.
Old Aug 2, 2004 | 02:21 AM
BigIslandSevens's Avatar
Is this for a track only car? If so then try a system like the following...
http://firecharger.com/
But if for ocasional tracking then the bins or a hard strap mounted to a secure area like the floor or a roll bar if you have one.
Old Aug 4, 2004 | 03:42 PM
Gene's Avatar
10 lb. boost, 5lb. bag
Firecharger looks sweet... though the Trogdor-esque mascot is a little cheesy.
I have mine secured with a bracket to the bottom of the driver's side roll bar hoop down near the floor, the bracket is attached to the rollbar with two hose clamps.
Old Aug 4, 2004 | 03:52 PM
DamonB's Avatar
I have an extinguisher bolted to the bottom of the passenger bin of my FD.
If my car were a track car only I would splurge for a true fire suppression system with nozzles in the engine bay and passenger compartment and a great big red handle to yank when things go wrong...
Old Aug 4, 2004 | 04:54 PM
RETed's Avatar
Fire extinguisher mounted under your / driver's seat right up front.
You need to make sure the furthest forward you're going to be adjusting the seat.
With that set, then you can go about mounting the fire extinguisher.
I find this placement the fastest and easiest to get to inside the car while in the driver's seat - no twisting, turning, or opening hatches or doors.
In a normal driving position, your feet (or any other part of your body) does not go into that area.
I can probably access the unit blind if a have to...which is something I have confidence in *if* there's smoke and fire inside the cockpit.
Check race regulations and rules about mount locations and type - many have restrictions on placement.
-Ted
Old Aug 5, 2004 | 04:49 PM
RX744CSP's Avatar
My 1st gen is IT prepped, so I use a metal bracket handheld on the center tunnel. I only autocross the car at the moment, if I do get the chance to do Solo 1 or any wheel to wheel stuff I'' do a Firecharger system.
For a street car, I'd mount it on the floor sideways in front of the passenger seat, using a metal bracket (much easier to get to than in front of the drivers' seat).
Old Aug 24, 2004 | 02:21 AM
Flyrx7's Avatar
Money Pit
Where is a good source for a nice automotive type extinguisher?
I was thinking of a nice polished stainless or chrome looking affair and was wondering if anyone had some good leads.
It seems to me that Pegasus has some... I guess I'll check there too.
Thanks,
Frank
Old Aug 30, 2004 | 06:42 PM
Cyrio's Avatar
I have 2.... one directly to my right, inbetween the driver's seat and the "hang on for dear life" seat. The other one is mounted in the passenger side rear corner with a pull cord located in the dash. The rear charger sprays the engine, rear, and right behind the driver.
chris
Old Sep 1, 2004 | 11:03 AM
Mr. Stock's Avatar
1993 RX7 R1
Thanks,
Frank
I have one from safecraft.com
http://safecraft.com/product_page.as...CatID=7&menu=H
Old Sep 1, 2004 | 03:52 PM
tao's Avatar
tao
Newbie
Fire Extinguisher
I just got mine rechargeable Halon unit from H3R http://www.h3r.com/products/home_vehicle.htm. They had a promotion in August. You can try get yours 10% discount by following these steps.
Select the product(s) you want to buy
Click on the "checkout" button
Click on the "Redeem Coupon" link
Type "1211" in the "Offer number" field
Click the "Redeem Coupon" button.
Old Sep 2, 2004 | 07:01 PM
macdaddy's Avatar
just a quick comment, on a related tangent: standard dry chemical is cheaper, but if you ever have to actually use it, you'll appreciate having Halon - no cleanup other than from the fire itself. The regular stuff takes forever to clean out of carpet, etc.
Old Sep 4, 2004 | 09:54 AM
fd3s_rx7's Avatar
Mine is mounted in the back of the driver seat...
Old Sep 4, 2004 | 06:20 PM
silver3rdgen's Avatar
Custom User Title**
hand-held halon on the tranny tunnel (makes a good elbow pad too to keep your arm off the hot *** tunnel) and a 10# halon system in back w/ 3 seperate spray heads
Old Sep 9, 2004 | 06:37 AM
VaGambler's Avatar
You might want to get an extra fire extinguisher. I heard you need it
ls1swap
Jun 3, 2024 03:25 PM
Aramir
Oct 18, 2015 02:39 AM
LongDuck
Oct 7, 2015 08:12 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
