I searched! My car idles AFTER I warm her up with the gas pedal depressed.
Old Jul 31, 2004 | 02:03 PM
Madrx7racer's Avatar
well bot times I have gotten my car to idle I have had to keep my foot on the gas for 10 seconds and then it idles, If I dont then it will stall and die......I searched and I could not find a solution...I searched for TPS and I got nothing. What could be wrong? How can I fix it? I will be going to San Jose today to insatll my boost gauge and clean out the interior and I would like to know if there is a fix for this.
Old Jul 31, 2004 | 02:19 PM
Syonyk's Avatar
Sounds like the cold start system (supposed to raise the idle when cold) isn't working properly. It's the thermal wax unit on the back of the throttle body with the coolant lines flowing through it.
-=Russ=-
Old Jul 31, 2004 | 02:22 PM
Turbo7MN's Avatar
S4 is sexay!
my 86 N/A does the exact same thing, only when cold though.
Old Jul 31, 2004 | 02:36 PM
-=Russ=-
How does that get fixed? or should I not bother? If it is important I will fix it, if it ONLY makes me stay in the car 10 more seconds then I don't care.
Old Jul 31, 2004 | 02:37 PM
Scott 89t2's Avatar
SOLD THE RX-7!
probably the thermowax. it should idle at 1500 when cold. if the thermowax isn't working it'll try to idle at 750 but can't.
Old Jul 31, 2004 | 02:41 PM
yeah...it goes down to 900 and the stalls out........after it is kinda warm it will idle on its own.......Should I find a fix or leave it alone?
Old Jul 31, 2004 | 03:46 PM
Syonyk's Avatar
Sounds like it's not working properly, or not adjusted properly.
If it doesn't bother you, then I'd personally leave it alone.
-=Russ=-
Old Jul 31, 2004 | 03:50 PM
Rx7MPGUY84's Avatar
Rpm abuser
mine does that, but i did the tb mod. if you did the tb mod, it will do that i think. but mine only does it when she's cold. did you do any mods?
Old Jul 31, 2004 | 07:12 PM
Parastie's Avatar
Mountain Rotary Mod
Junk yard will be your best bet to find the thermowax, but it's not really a major problem unless it annoys you.
My car does the same thing and i have to hold the throttle open until the car has warmed up enough for me to drive it around.
Old Jul 31, 2004 | 07:16 PM
QStyle's Avatar
Newbie
I am having a similar problem with idle, where after the car starts it idles at 1500 then drops under 1000 then goes back to 1500. It seemed to stop doing this after a few minutes, is it because the engine needed to be warmed up?
Old Aug 1, 2004 | 12:33 AM
I will leave it alone then....thanks you guys
Kyo
Apr 13, 2019 09:24 AM
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
smikels
Aug 18, 2015 01:26 PM
bb6guy
Aug 12, 2015 03:29 PM
