For those with S4 6 ports and did an airpump conversion for the ports... Question.
Old Jul 27, 2004 | 11:56 AM
poor_red_neck's Avatar
Wait................What?
For any of you that have the 6 port actuators hooked upto the airpump... how is yours connected?
Mine just has a nipple coming out of the air tube from the pump to the ACV. My concern is that it wont really have any pressure to power the pump since at higher RPMs the ACV gets its air dumped out. (relief)
I'm probaby under-estimating the airpump, but dont know of another way to do it.
Old Jul 27, 2004 | 01:40 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
I used a summit RPM switch connected to a s-5 stock 6-port solenoid. the 6-port solenoid was inline between the hose parb in the air pump and the air input nipple for the actuators. set the switch at 4.5K. worked flawlessly.
Old Jul 27, 2004 | 01:57 PM
HAILERS's Avatar
HAILERS
My remaining 86na has about the same setup as yearsofdecay. It works just fine each and everytime.
Just make sure you tap the airpump air b/t the airpump and the acv and not after the acv.
To prove that it works at high rpms or over 3800rpm is easy. Make the Relief Valve....relieve. You can do that by removing the Blue elec plug from its solenoid, then reving the engine and watching the auxillary port actuators.
Old Jul 27, 2004 | 05:13 PM
Well, I have a S5 ECU... so I have the brown solenoid plug for the 6 ports.. its not a problem of them opening on time, its if it will get enough pressure where its being "tapped".
HAILERS,
AFAIK, my ACV works properly.... I took it apart and cleaned all the springs, and made sure all the vacuum activated valves work. However when its removed from the LIM, I blow into the ACV "inlet" (from the airpump) it flows directly out the output (to the silencer). Is that correct? This is a S4 airpump btw.... S5 ECU.
josef 91 vert
14
Sep 17, 2015 09:22 PM
