Stock boost sensor questions
Old Jul 27, 2004 | 09:46 AM
hIGGI's Avatar
Question Stock boost sensor questions
Hey guys
As noted in FSM, stock boost gauge should go to zero when key ON, and then once started and idling it should be showing vacuum.
Whats wrong when it doesnt go to zero when key on? When i apply pressure to boost sensor, it seems to be working, but it doesn`t do that zero at key on. It was working before, i suspect some of grounding problem? Replacing boost sensor did not helped. Any ideas? FSM not really helped.
thanks
Old Jul 27, 2004 | 09:51 AM
WAYNE88N/A's Avatar
How close to zero is it? It could be something as simple as a gauge that hangs up at a certain point until actual pressures move the indication again...If it works great at all other times (or seems to), why worry about it?
Old Jul 27, 2004 | 09:53 AM
hIGGI's Avatar
It does not do anything on key ON
Old Jul 27, 2004 | 12:44 PM
jacobcartmill's Avatar
just dont care.
do you have an fcd?
Old Jul 27, 2004 | 03:32 PM
hIGGI's Avatar
no fcd, car is stock
Old Jul 27, 2004 | 04:20 PM
OverDriven's Avatar
Mine just died the other day...but yes it goes to zero when accessories are on, but the car is not started.
-Joe
Old Jul 27, 2004 | 05:37 PM
hIGGI's Avatar
anyone experienced same problem ?
Old Jul 27, 2004 | 08:06 PM
HAILERS's Avatar
HAILERS
A lot of turbo cars boost gauge needle will not go all the way to zero. It's not an uncommon problem.
Try this: Pull the vacuum line off the boost sensor. Plug that line. Leave the boodt nipple open.
Start the car. Most likely the boost gauge needle will now come closer to being on zero.
The lesson I think I learned from this is........that the problem is voltage related or maybe the contacts on the back of the combination meter need to be cleaned and reinstalled. Try it and see what your results are and if you agree with what I think.
Old Jul 28, 2004 | 03:12 AM
J-Rat's Avatar
Alcohol Fueled!
Mine does it all the time. Tap the gauge cluster, it makes it start working!
Old Jul 28, 2004 | 04:23 AM
Impreza2RX7's Avatar
I'd get an aftermarket boost gauge too, it's a good investment..
Old Jul 28, 2004 | 10:18 AM
Travelintrevor's Avatar
B.G.O.B.G.A.I.
i have that probem..with a stock rx7 turbo( no boost controller) you might find yourself not boosting all the way...does that happen to you?..feels low on power sometimes??
Old Jul 28, 2004 | 04:22 PM
hIGGI's Avatar
hard to say since i have not driven that car for few months and its not really compareable to my other FC
Old Jul 30, 2004 | 03:35 PM
B.G.O.B.G.A.I.
so pull the boost sensor out of your other car and see what happens
Old Jul 31, 2004 | 03:07 AM
hIGGI's Avatar
My other car has no boost sensor, its running on Haltech (and MAP sensor)
Old Sep 6, 2004 | 06:41 PM
anobii's Avatar
Maah, i am having the same problem, the boost gauge works intermittenly but mostly not at all. changed the sensor, still the same. To tell wether it's a wireing problem between the sensor and ecu, pull the codes, if you get a pressure sensor code (code 13) the the ecu is not seeing the correct voltage numbers from the pressure sensor as they relate to the AFM. In the FSM is says if the Pressure code is thrown, it changes the fuel map (most likely to full rich) and fixes the timing ( no advance). This i can verify kills LOADS of power. It tells how to fix the problem in the FSM (page f2-25 under fuel and emission systems). I'm thinking its a bad ground. I haven't got around to fixing it yet though. thought i'd add a little,
-E
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
