How Much Oil?
Old Jul 25, 2004 | 10:39 AM
Directfreak's Avatar
I am a Jeeper Now.
How Much Oil?
How Much Oil does it take to do a regular Oil change on a GSL-SE?
Is it 4 quarts, 4.5 quarts or 5 quarts?
1) I don't have an owners manual,
2) I have a Cosmo engine
3) I have a GSL-SE Oil Pan
4) I have a Cosmo Dipstick.
I should have kept my GSL-SE disptick, to match
the GSL-SE Oil Pan.
GSL-SE Owners:
Please look it up and let me know.
Thanks!
Old Jul 25, 2004 | 01:06 PM
I am a Jeeper Now.
Bump - need the info..
Old Jul 25, 2004 | 04:36 PM
I am a Jeeper Now.
Damn. Nobody could look this up?
Old Jul 25, 2004 | 04:44 PM
r0taryluv's Avatar
Mr.SEBoost
Here you go Alex.... total oil Capacity is 5.8 US qts in the 13b, this is out of the Workshop manuel.
Old Jul 25, 2004 | 04:48 PM
j9fd3s's Avatar
Community Builder
cosmo/ fc dipsticks were the same. i wanna say 24" but its posed in the 20b section, long long ago
Old Jul 25, 2004 | 05:11 PM
Jeff20B's Avatar
Lapping = Fapping
Should the oil level, when full, be at the pan gasket surface at the middle of the engine where the dipstick is? The engine is slightly tilted, but I think the oil level should be right around there, or maybe a little above. Does that make any sense?
Old Jul 25, 2004 | 05:37 PM
gonzz's Avatar
I just changed my oil and filter in my 13B 4 port. I put in 5 quarts exactly.
Old Jul 25, 2004 | 07:44 PM
elwood's Avatar
The amount of oil you use in an oil change can't be predicted very accurately by the total system oil capacity. In most cases, you can't get all the oil out, so a system with 5.8 qt capacity that needs 5 qts for an oil change makes sense. Why do you need to know exacly how much oil? When you change the oil, check the dipstick after the fourth quart and add until it's where you like it. I like mine near the 'F' -- more is better, the American way.
Check it again after you run the engine. It'll probably drop a little from that, too.
Old Jul 25, 2004 | 08:19 PM
rxseven's Avatar
Special Dark
I have never exceeded 4.5 quarts on any oil change ever with a gsl-se. Most of the time 4 quarts works as it leaves it just under the F mark which is what I like.
Old Jul 25, 2004 | 09:42 PM
BARF1's Avatar
Who are you?
Not that this really pertains to this subject but I once knew a lady who ran her car a quart low on oil because she said it was "good for it". Man some people are stupid.
Old Jul 25, 2004 | 10:30 PM
1984se's Avatar
Ryan
4.5 on my GSL-SE
-Ryan
Old Jul 26, 2004 | 09:00 AM
sgieldon's Avatar
What if you run an 80 style Rad & Oil Cooler i.e. under it???
Installed w/84GSL Motor12A.
When I change mine 5quarts my DipShit shows alittle over the full line.
(Very Little)!
sgieldon
Old Jul 26, 2004 | 10:38 AM
I am a Jeeper Now.
I used 5 quarts.
Old Jul 26, 2004 | 11:24 AM
Rex4Life's Avatar
RX-7 Alumni
I remember looking at this when I had my SE engine and T2 engine out of the car. Ended up the dip stick tube in the center housing is different so the dipstick needs to go with the center housing.
If you have a cosmo center housing I'd stick with the cosmo dipstick.
Scott
Old Jul 26, 2004 | 12:36 PM
680RWHP12A's Avatar
5 quarts
Old Jul 26, 2004 | 01:30 PM
MarkPerez's Avatar
Tennis, anyone
it's 5 guarts DF
Old Jul 26, 2004 | 01:41 PM
fatboy7's Avatar
Got Boost?
5 quarts is pretty usual. the 5.8 quarts remember includes the oil in the oil cooler, the oil lines, and oil filter.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
