car dies when ac is on and clutch is depressed
Old Nov 16, 2001 | 11:49 PM
njm's Avatar
njm
every time i run my car with the ac on i have a problem. it seems to run fine except when i press the clutch in . it loses rpms and dies. can anybody tell me the problem ? thanks
Old Nov 17, 2001 | 12:09 AM
dis1's Avatar
www.silverbulletrx7.com
Did ya check the clutch switch?
cvs
Old Nov 17, 2001 | 02:10 AM
The Sloth
CHECK THE IDLE COMPENSATION SWITCH.
Old Nov 17, 2001 | 05:57 AM
bbr1's Avatar
Also make sure that your ECU was replaced under recall (if yours is a '93). There was a recall back in '93 for this very problem.
Old Nov 17, 2001 | 11:09 AM
Brian_7's Avatar
Check you clutch switch
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
