OH MY GOD.. turbo 12a put on serious hold!!
Old Jul 11, 2004 | 08:50 AM
FB II's Avatar
Angry OH MY GOD.. turbo 12a put on serious hold!!
well today was the day. i was grabbing the last couple pieces of the exhaust to be welded and done when i looked at my engine bay just because i am so happy. i look down at the floor and i see coolant EVERYWHERE. OH FUGGIN NO!!!! what the hell is this? i get under the car and see it's almost friggin just pouring out. last night i had jacked the car up on the drivers side to work on the fender. i guess this pushed the coolant over thru the manifold. there wasnt much left in the motor. i had to refill it since putting the intake on. well i see it's all over my turbo. had obviously killed the gasket between the turbo and exhaust manifold. so i say fork it. i pull the turbo off and coolant just FLOODS out of the manifold ports. can this stuff mess gaskets up???? ahhh, anyways in this intake manifold i notice a damn tiny hole just leaking coolant. i get back under the car and coolant is leaking out where the gasket is. but only on the manifold side. it's not flush. i re did it and tried another gasket. same thing. BASICALLY i need a new intake manifold but i cant use a stock one because then i have to redo how i'm going to space the turbo out. i got this intake manifold from Robert at Rotary Shack and he ported it and made the acv area alot smaller to give room for the turbo. i am not bashing or anything, it is a damn nice piece of work, but i can not use it now. i am depressed. i did not sleep at all last night just thinking of how awesome it was going to be to finally drive this beast after months and months of building and waiting on parts. here are pics.
right now i have no motivation to mess with this car any further.
Old Jul 11, 2004 | 09:17 AM
83gslRX-7's Avatar
damn that sucks, im sorry buddy.
Old Jul 11, 2004 | 09:27 AM
Rx7carl's Avatar
Airflow is my life
No big deal man. Plug the coolant passages in the rotor housings so no coolant goes into the manifold. Wouldnt that solve your problem?
Old Jul 11, 2004 | 09:29 AM
FB II's Avatar
well here is part of the problem.
this can be welded closed, what are these manifolds made of? (stock ones)
also, carl.. what would i use to block the passages on the rotor housings???? sounds like the damn perfect idea
Old Jul 11, 2004 | 09:33 AM
Rx7carl's Avatar
Airflow is my life
They are made out of aluminum. The face of that manifold doesnt look very flat, looks uneven, might cause you to have leaks. Hell just JB weld that little hole.
I use 20mm freeze plugs (autozone) and hammer them into the housing. Some guys just epoxy quarters to block the holes.
Old Jul 11, 2004 | 09:35 AM
FB II's Avatar
yea, i stated that earlier that i think it's uneven. thanks for the second opinion. i wasn't sure if i was just an idiot with no sleep right now. i'm going to autozone here in a bit and looking for freeze plugs baby!!! thanks carl, you always have the good ideas WOOO!
Old Jul 11, 2004 | 10:28 AM
coldy13's Avatar
Yeah, shutup kid.
It does look uneven, but it's good enough. While you're at autozone get silicone gasket sealer. Just lightly coat both sides of the intake manifold gasket with it right before you put it on. Also, the exhaust gasket that got coolant all over it will be fine, don't worry about that.
Old Jul 11, 2004 | 11:21 AM
FB II's Avatar
well, it's all back together now. i plugged the coolant holes and rtv'd the manifold a lil' bit. hahaha! WOOOO!!!!!! i sure did panic
Old Jul 11, 2004 | 12:00 PM
seanrot's Avatar
Always waiting for parts!
That's good to hear. I glad your making progress. My 12a turbo just hit another pit fall. Waiting on parts. Just got a urethane float for my weber IDA, only one I have ever seen but it will solve all the problems I'm have with the sinking brass ones
I should have it in about two or three weeks
Old Jul 11, 2004 | 12:16 PM
83gslRX-7's Avatar
glad to hear that everything is back in order you and john better get your exh. done today, and you better come to rock and roll emporium.
Old Jul 11, 2004 | 03:17 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
It's always great when it's not as bad as you thought.
Old Jul 11, 2004 | 04:13 PM
FB II's Avatar
hell yea sterl; i do believe the leak is GONE! MUHUAHAHAAAA and my exhuast is half *** done! hahaha, well it's done for what i have. it's probably gonna be loud as nawlz but i just want to get this fu$%er running! but yea this morning i was sad as hell. i'm doing pretty good now. OK time to go fit this **** up there and see if my calculations were correct!!! WOOOOOOT!
Old Jul 11, 2004 | 07:18 PM
REVHED's Avatar
Hunting Skylines
Where did you get the float from?
Old Jul 11, 2004 | 07:58 PM
seanrot's Avatar
I just did thread on it.here
Old Jul 11, 2004 | 08:37 PM
Sterling's Avatar
Nobody wants to know as bad as me!
Keep us posted.
Old Jul 11, 2004 | 11:34 PM
FB II's Avatar
well, didnt get a chance to fit the exhaust. will definitely do it today though. right after i made that post my aunt was in a car wreck. so i had to attend to her need. everything is a-ok though
Old Jul 15, 2004 | 05:06 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
That's good. So how did the exhaust go?
Old Jul 15, 2004 | 10:58 AM
FB II's Avatar
the exhaust is kindaaaaaa ugh... it will work perfectly i just gotta fab up a hanger for it. which is hard. i'm gonna try firing it up today regardless. if nothing gets in my way again. it seems since everything has been ready to rock, SOMETHING always comes up that keeps me from testing the seven!!!!! ARRG!
Old Jul 15, 2004 | 11:29 AM
snake eyes<l><l>'s Avatar
&lt;l&gt;&lt;l&gt;
duh, otherwise it wouldn't be any fun keep us updated, im curious on how this will turn out
<l><l>
Old Jul 15, 2004 | 11:35 AM
dark mephisto's Avatar
Rotating once again!!
aka-cops knocking on your door because your neighbours didn't enjoy being woken up
Old Jul 15, 2004 | 12:18 PM
seanrot's Avatar
Just a little way to cheat on the hanger. get an exhaust clamp and weld to that. Then bolt it to the pipe. My Friends Gibson exhaust for his S-10 did it that way for one on the hanging points. Figured it was a good idea and I'm going to do it shortly.
Old Jul 15, 2004 | 12:30 PM
FB II's Avatar
yea, i'm hoping my friend will be bringing his welder over today
Old Jul 15, 2004 | 12:43 PM
lol, go canadian tire hangers!!! no welding required. all i did was use an exhaust clamp and then clamp the hanger to the exhaust via the clamp and bingo, works like a charm, takes about 3 mins. but you guys don't have an canadian tire down there.
CaptainKRM
14
Aug 26, 2015 09:52 PM
cam_7779
Aug 18, 2015 07:48 AM
Marty RE
Aug 13, 2015 11:19 AM
