replacing downpipe studs...?
Old Nov 15, 2001 | 03:46 PM
ejmack1's Avatar
Lawn Ornament
is this somethin i could do on a saturday and have the car running by the afternoon, the exhaust leak has finally pissed me off enough for me to the damn thing apart and replace it, by the way anyone know how much they cost and if they have to be ordered or if mazda stocks them
Old Nov 15, 2001 | 04:01 PM
Bacon's Avatar
IRS 4 Life
well if your mechanicly inclined yea, it should be a quick turn arround..., are the studs broken, just loose..not there??? if their just loost its just a mater of tightning them, if you have to replace them mazda should have them in stock, but their pretty expensive somehting like 10 bux a stud and 8 bux a nut...
Old Nov 15, 2001 | 07:29 PM
ejmack1's Avatar
Lawn Ornament
do they carry the studs anywhere else? it is just stripped, and i think i can twist it out....
Old Nov 15, 2001 | 07:35 PM
Bacon's Avatar
IRS 4 Life
i forget the thread size but if you can find some grade 8 stainless you can just replace them...take the nut to pep boys, or in my case the loncal hardware store(carries more nuts an bolts that anywhere i know)
Old Nov 15, 2001 | 10:22 PM
DavidZ's Avatar
If the studs are only mildly stripped, you may be able to salvage them by using a tap and die set to straighten out the threads.
best way i have found to remove the studs are to soak overnight with some penetrating lubricant(WD-40, liquid wrench, etc...), then place two nuts onto the stud and tighten them against each other, then you can use a box-end wrench to turn the inner bolt and backing the stud out. if it doesn't budge, invest in a propane torch.
Old Nov 15, 2001 | 11:54 PM
Mach2's Avatar
If they've never been moved or its been a long time since you last removed them, then it will probably take you some time. This is the worst place to rush, cause those bolts will sieze, strip, snap faster than you can say "****!" What I did was remove the studs entirely and install bolts instead. This way I can easily remove my dp(without the studs in the way), and I'm positive that I'll be able to remove all four of them every single time. I find them alot easier to work with especially if you have to remove the dp often. I don't think you'll be able to do this as quickly as you think though. Good luck!
Old Nov 16, 2001 | 08:35 AM
Tim McCreary's Avatar
Whatever you do, use some type of neverseize compound on the threads when reassembling. Copper type or zinc type. Makes the bolts come back off like it was buttered. A definite MUST for any exhaust work.
Tim
Old Nov 16, 2001 | 10:12 AM
Mach2's Avatar
Tim is 100% correct! I "always" use a copper based anti-sieze compound on "all" the exhaust bolts, and I haven't stripped a bolt yet. They back out very easily, but don't think they'll wiggle loose cause they won't. Very good advice right there! Kudos to Tim!
Old Nov 16, 2001 | 01:23 PM
65Imp's Avatar
Performance Part Purveyor
I gotta replace my studs too.
Does Anyone know what size/length to buy? I know Stainless and grade 8. Also places that sell them in your area.
Thanks
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
Nosferatu
Sep 5, 2015 02:13 PM
Apoc3D
Sep 5, 2015 10:24 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
