RX6 turbo and injector questions
Old Jul 3, 2004 | 05:14 PM
Indo Audio's Avatar
I have the following:
Stock engine
RX6B turbo
PFS SMIC
SX fpr
walbro 255 pump
1200CC secondaries
xs ignition
midpipe
gt spec catback
Greddy pulleys
Would you keep the stock primaries or put the stock secondary 850cc in the 550cc primaries? Would I run too rich if I did that, or just keep the 550cc in there? Most likely aiming 370 rwhp.
Thanks,
Ravi
Old Jul 3, 2004 | 05:15 PM
Indo Audio's Avatar
Also have PFC, sorry.
Old Jul 3, 2004 | 07:10 PM
MR_Rick's Avatar
Planning my come back
I would put the 850's in the primary to play it safe, or send them to me
Old Jul 3, 2004 | 07:11 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
550's are fine for 370. You can run the 850's, but it's not really necessary at that level.
Old Jul 3, 2004 | 07:54 PM
Wargasm's Avatar
Weird Cat Man
Honestly I think that if you can do it without too much hassle, you should use your 850s in the primary spot.
2x550 and 2x1200 will not leave as much safety room as I would like if it were my car trying to make 370 rwhp.
If you get the 850s properly installed in there and tuned for it and everything you will be very glad you have that extra capacity I think.
Brian
Old Jul 3, 2004 | 08:04 PM
Wargasm's Avatar
Weird Cat Man
Oh and just for reference... a handy little "quick calculation" I do is this...
Take your total fuel delivery in cc/min and divide by 10 and that's your rwhp you can make on those injectors.
so in your case...
(2 x 550) + (2 x 1200) = 3500
3500/10 = 350 rwhp
That's a rough calculation, and is based on 36 PSI of fuel pressure at 0 manifold pressure. So if you're running say 40 PSI of fuel pressure at 0 manifold pressure, you'd squeeze a few more out than that... but my "rule" works to be sure you're safe since it's based on 36 which is fairly low.
Old Jul 3, 2004 | 09:06 PM
1FooknTiteFD's Avatar
Ghost Ride the Whip
i have a very similar setup to yours, i made 378rwhp on the XS dyno with stock primaries but with 1300 cc injectors on 91 octane
Old Jul 3, 2004 | 09:27 PM
Rhode_Dog's Avatar
\m/
http://rx7.com/cgi-local/3rdgencalc.cgi
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
