Sponsored by: CARiD
Flooding Problem
Old Jul 3, 2004 | 12:22 AM
Bedwyr's Avatar
Newbie
Flooding Problem
I have a na RX-7 88 the problem is that after it's started and has warmed up(revs high for a bit then drops down once warmed up) it wants to "flood" when given gas. I'm going to check the TPS and set it if needed. Should I be checking anything else?
I'm new to the rotary engine btw.
Old Jul 9, 2004 | 01:57 PM
Cosmo Donk's Avatar
Queer
TPS, spark plugs, wires, throw on a ground strap, check to make sure the coils are grounded well, make sure injectors are clean.
Old Jul 16, 2004 | 01:01 AM
Bedwyr's Avatar
Newbie
The plugs are new as are the wires. Ground Strap and the coils k I'll give it a try. As for the TPS I was getting good ohms reading on the A B Idle approx 1k and Full open 5k +/- 1k How ever the Tech Manual states that the A C ohms is the same for Idle and Full Open was this a misprint? If not then I've found it. A C is 5 +/- 1k but Full open is around 1K. And Thanks for the reply.
tidanb0utch
11
Oct 7, 2015 07:36 AM
FbFuninthesun
Oct 6, 2015 08:03 AM
PinkRacer
43
Oct 1, 2015 09:13 AM
Monsterbox
Sep 11, 2015 03:29 PM
