Sponsored by: CARiD
no start 3rd gen
Old Nov 14, 2001 | 10:25 AM
Hyperite's Avatar
Vagina Junction
You'll need to replace the plugs, gasoline soak ***** them up. I've been there. Also, crank it a few times w/ the plugs out (AND IGNITION STUFF CAPPED/DISCONNECTED TO PREVENT EXPLOSION!). Then put in some new plugs, make sure you ARE getting a spark, and give it another try. If you're getting gas, spark, and air, it can't help BUT fire. Check the plug wires and make sure they haven't fallen off the coil. Leading ones will affect starting. Good luck!
~Tom
Old Nov 15, 2001 | 09:19 AM
gnx261's Avatar
Newbie
The starter switch may be bad as mine was recently. you may want to check it. doug
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
R7rexy
19
Sep 2, 2015 10:24 AM
