GSL-SE Gastank in 80 Chassis
Old Jun 24, 2004 | 03:04 PM
Phiber Optik's Avatar
V8 RX-7
I have put my GSL-SE gastank in my 80 rx7 project car. The motor is going to fuel injection. I almost have everything done, including modifying the spare tire well, except the gas level sensor. The GSL-SE tank has 3 pins and the plug connector on the 80 chassis has 2 pins. Does anyone know what wires to connect?
Old Jun 24, 2004 | 06:46 PM
Frankenrex's Avatar
Wiring diagrams for all years on my site (see sig)
Old Jun 24, 2004 | 07:27 PM
gonzz's Avatar
What did you have to do to make the 85 tank fit? Did you cut the spare tire hole?
Old Jun 24, 2004 | 07:40 PM
Frankenrex's Avatar
Had a second to look at the diagrams. The extra wire on the '85 tank is for the low fuel warning light, you can leave it disconnected.
'85 wires, tank side of connector:
Yellow/blue is warning light
Yellow is to the gauge
Black is ground
'80 wires, car side of connector:
Black is ground
So just match the colors and don't worry about the yellow with blue stripe.
Old Jun 25, 2004 | 01:00 PM
V8 RX-7
gonzz: I cut it out and then put it back it from the top not so deep and then notched the excess metal and then hammered it flatand welded it all up. Let me know if you are interested in pics.
Frankenrex: thanx for the help!
Old Jun 25, 2004 | 11:42 PM
Frankenrex's Avatar
Any time. I may need to do this myself to convert my '79 to an SE.
Old Jun 25, 2004 | 11:51 PM
kuhlrx7's Avatar
Unconfirmed
I installed a gslse tank in my 79 and did not do any thing to the spare tire location. I just bought longer bolts. no need to cut anything.
Old Jun 26, 2004 | 02:43 AM
gonzz's Avatar
Post or send me some pics...
Old Jun 26, 2004 | 09:33 AM
Frankenrex's Avatar
Does it hang down any lower, and if so, how much?
Old Jun 26, 2004 | 11:53 AM
hammmy's Avatar
Probably however much Phiber raised his spare tire well. =P.
Old Jun 28, 2004 | 09:42 PM
gonzz's Avatar
I wonder how lower the 79/80 well is compared to a -se?
Old Jun 28, 2004 | 11:20 PM
V8 RX-7
the 80 is 3" lower
7" on the 80 and 4" on the SE
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
NickNac113
13
Oct 1, 2015 09:25 PM
