View Poll Results: Should I bridgeport it or should I do a big ass street port?
Hell yes! Crazy idling and mad flow are key to getting ahead in life.
13
40.63%
Sure, but its going to suck to drive on a daily basis
15.63%
Nah, a big street port is almost as good, and has better drivability too.
37.50%
WHAT THE HELL DO YOU NEED A BRIDGEPORT FOR???
6.25%
Voters: 32. You may not vote on this poll
Bridgeport turbo 12a???
Old Jun 24, 2004 | 06:56 AM
shm21284's Avatar
Fabrineer
Arrow Bridgeport turbo 12a???
Well, I am rebuilding my engine after a recent dumbass attack; that is, running 15 psi with the stock fuel pump. Don't freak, its not as bad as it sounds. I have a drawthrough so the fuel pressure is not an issue, but supply when flooring it for long periods of time is (the float bowls eventually get sucked dry and I end up with mad detonation). So, I cracked her down last night and I had the cracked rear cast plate at the upper dowel pin, and I broke 2 of Atkins solid corner seals (which I find very odd considering Coldy13 detonated his engine and broke a side seal and not the stock corner seals).
Anywho, I am contemplating a bridgeport. If I dont bridgeport it, I will definately street port it. Does anyone know how bad it's going to be for a daily driver? Will it suck *** to start from a stop? Oh yeah, I have a lightweight flywheel on the way (I believe its 13 lbs), so thats another thing to think about on the launch. I know that bridgeports are really good for a higher revving engine, but being that I am turbocharged, and a decently sized one at that (about the size of a T-04 E), it can flow that port size. Thanks for your input.
Old Jun 24, 2004 | 08:44 AM
rotary emotions's Avatar
HEAVY METAL THUNDER
I'd go for a big streetport. When turbocharging a Bridgeport, you have a good chance of blowing out the bridge sooner or later (and probable sooner then expected)
I'm not aware of many BP turbo'd engines, so I guess that'll have a reason. The bridge is already the weakest link, so I wouldn't put extra stress on it.
Old Jun 24, 2004 | 09:39 AM
YapaKanichi's Avatar
Smile Like a Donut
street port is drivable, not to bad. It's like driving a really fast car though lol.
Old Jun 24, 2004 | 11:55 AM
shm21284's Avatar
Fabrineer
yeah, ill do the street port. Its not worth bridge porting, especially considering the poor drivability of a bridgeport and the fact that its carbureted (drawthrough turbo at that). Plus, I dont want my engine to blow again anytime soon lol.
Old Jun 24, 2004 | 12:49 PM
HEAVY METAL THUNDER
well, don't let drivebility put you off. Reliability should
People tell a lot of tales about BP and PP, but even PP is streetable as such. It's just most PP's are build hardcore race-prepped. But the old NSU engines were PP and they weren't at all undriveable. The very early ones were a bit unreliable, but that's all long solved (now 100.000miles on a PP NSU are "normal"). So all porting types can be turned to a streetable engine.
Old Jun 24, 2004 | 12:54 PM
pillage6's Avatar
I was thinking about doing the bridgeport turbo thing, but decided on a 120 shot instead.
Old Jun 24, 2004 | 01:02 PM
680RWHP12A's Avatar
i have a bridgeport turbo.....the best way to explain it is.......with a bridge turbo when you get to high rpm's(above 6k) it feels like the second turbo kicks in!!! nothing like it!!
as far as driveability goes, its **** and plan on using tons of gas, its worth it if you ask me
Old Jun 24, 2004 | 01:13 PM
The Wankler's Avatar
FKITALL
If you live in Cali, forget about it! I think my RotaryShack street ported 12a turbo will be plenty!
Hint hint!!!!!!
I can not wait!
Old Jun 24, 2004 | 05:44 PM
Junia's Avatar
Uchinanchu
I'd go bridgeport but keep it n/a. You guys gotta admit that theres nothing like the sound of a n/a rotary at aroun 9000-10000 rpm.
Old Jun 24, 2004 | 06:09 PM
comradegiant's Avatar
I hate because I'm bored.
I always wanted to PP my 12a, build the internals and get some lightened race rotors so I could run at 14K like the IMSA cars did. Wouldn't last for a goddamn, but it would be fun while it lasted.
Old Jun 25, 2004 | 01:43 AM
Jon_Valjean's Avatar
Overlap and forced induction don't usually co-exist without some fairly major work. If you want power, get a large street port with no overlap and slap a T04-s running 15psi or something. If you want noise, unreliability, excessive fuel consumption and roughly half the power, get a wild bridgeport/J-Port.
Admittedly, not all bridge/J's are completely impossible to drive below 3000rpm, but the good ones are. Even quite wild turbo jobs are quite driveable at all rev ranges.
Old Jun 25, 2004 | 02:12 AM
Directfreak's Avatar
I am a Jeeper Now.
Turbo Bridgeports kick ***, however, the power band is very narrow, compared to a streetport turbo.
I have experienced both. The bridge sucked *** around town driving, but really shined when racing and running biiig boost.
Old Jun 25, 2004 | 02:46 AM
12at's Avatar
10.21 @ 137mph
I agree with 680RWHP12A. Bridgeport turbos are awesome.
It is not any harder than driving an NA bridgeport around.
Old Jun 25, 2004 | 04:27 AM
Admittedly, I've never tested a bridgeport turbo with my "seat-of-the-pant-o-meter", but if it's anything like driving a n/a big bridge (of which I've owned two, and driven over 60,000 miles in) then it's hardly easy to drive and I can't say with confidence it's an image (noise.. noise.. backfiring.. more noise.. did I mention the noise?) I'd want to perpetuate now I'm 25 and not 17 anymore
I henceforth withdraw my previous comment regarding fuel consumption. All rotary engines consume fuel in a manner that makes an Iraqi oil well fire look tame and the 17 y/o in me is screaming "you drive it for fun! don't look at the fuel gauge!"
Old Aug 14, 2005 | 10:57 PM
AlexG13B's Avatar
brap brap brap
what brand turbo? wat about using a TII turbo on a 12aBP running stock boost?
Old Aug 15, 2005 | 12:32 AM
OneRotor's Avatar
RAWR
the guy i bought my car from said that it has a bridge port, and it's a 12a in an '82. It idles between 1800 and 2k,, and anything below 3k it starts to get jumpy when cruising, but up around 7 or 8k rpm, it really pulls nicely. I'm afraid to take mine above 8k because of the possibility of seal chatter. as far as turbo'ing a bridge port, there is a guy in the 3rd gen section that posted a video of his bridge ported T78 car, and that thing screamed. went from 3k to 8k in less than a second, in second gear.
Old Aug 15, 2005 | 12:35 AM
kenn_chan's Avatar
Savanna Rx-7
Imagine trying to drive any car with a potato stuffed in the exhaust the back pressure soon kills it, that what running a S-4, or S-5 turbine on a 12a or 13b bridgeport would be like. these engines BP/PP require race level exhausts to spin up as NA's something with a "P" trim wheel and a 1.15, or 1.32 might work well and truly extract all of the power a turbo bp could make but any less and you would be just as well off with a street ported turbo.
kenn
Old Aug 15, 2005 | 02:31 AM
FB II's Avatar
do a "half-bridge", you get great street drivability and amazing top end. put a 70mm turbo on there with atleast a 1.15 "p" trim turbine and you will never look back. altho, you are carb'd so.... nevermind. to really tune that sucker you would need a haltech ( and this is coming from a turbo carb'd 1st gen owner too ). a nice large streetport would be plenty. go big on the exhaust ports so you spool the **** out of your turbo. and you might want to think about getting something bigger
Old Aug 15, 2005 | 03:38 AM
12at's Avatar
10.21 @ 137mph
Just thought I would tease you with a little video of my bridgeported 12aT idling in the driveway. Enjoy.
http://rapidshare.de/files/3965198/b..._idle.AVI.html
Old Aug 15, 2005 | 04:06 AM
FB II's Avatar
hell yes! sounds awesome, idles alot faster than most i've been around but definately a bridge none-theless!!! hahaha. one question.. if you are using a 12a with TII intake manifolds and the plate adaptor to make them fit.. . what did you do about the injectors that normally go in the housings?
Old Aug 15, 2005 | 04:19 AM
12at's Avatar
10.21 @ 137mph
The fuel injectors are in the centre plate like a 13bt. It is only the oil injectors in the housings. I have blocked those and I premix oil in the fuel.
Old Aug 15, 2005 | 04:28 AM
FB II's Avatar
ohhhh niiiiiice. man i'm loving your setup more and more everytime i ask you a question
Old Aug 16, 2005 | 03:26 AM
12at's Avatar
10.21 @ 137mph
And another small video. Not my fastest run but close to it.
http://rapidshare.de/files/4030600/b...-12aT.mpg.html
Old Aug 16, 2005 | 04:02 AM
IanS's Avatar
Ricer
best post EVER
The1Sun
Mar 18, 2018 11:08 PM
schaft
Time Slips and Dyno
Sep 9, 2015 02:02 PM
Josh83rx7
Sep 2, 2015 05:57 PM
rx7brandon
Aug 16, 2015 10:55 AM
Engine stand ready
Aug 14, 2015 10:26 PM
