IC pipping size?
Old Jun 23, 2004 | 12:08 AM
sk8world's Avatar
Chasing numbers
IC pipping size?
Just wondered what most of you are using.. I need to fab inlet and outlet IC pipping. What size? Is 3 inch ok? Should I use 2.75? Gt40r turbo on Apexi FMIC. Thanks
Old Jun 23, 2004 | 12:29 AM
bcty's Avatar
Boost This!
2.5" will be fine 2.75 will be fine any size around there would be fine for you
Old Jun 23, 2004 | 03:00 AM
sub9lulu's Avatar
is 3" going to make pressure drop or dont matter ?
Old Jun 23, 2004 | 03:37 AM
maxcooper's Avatar
WWFSMD
Stock piping is 2.75". Most turbos used on RX-7s have 2.5" compressor outlets. Measure the IC inlet and use that size, so long as you can clear the hood with it. You'll probably need a transition at some point to match the size of the turbo outlet.
Pressure drop comes from restriction, so a 3" pipe will have less pressure drop than a smaller one. Transitions add restriction, too, so it wouldn't make sense to go from 2.5" turbo outlet to 3" pipe to 2.75" IC inlet. Better to just transition once: 2.5 turbo outlet to 2.75" pipe to 2.75" IC inlet (or use 2.5" pipe). Bigger pipe adds volume but has lower restriction. Smaller pipe has less volume but is more restrictive.
-Max
Old Jun 23, 2004 | 12:35 PM
FD Rey's Avatar
I brake boost
How much power are you looking for? How big is the IC endtank inlet pipe? And how big is your turbo outlet?
This will help alot! Just let us know and when can advise you.
Old Jun 23, 2004 | 06:03 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Corky bell says..
Corky Bell's Maximum Boost - Pg 61 There is probably a magic number that airflow velocity in a tube should not exceed, for reasons of rapidly increasing drag and consequent flow losses. I suspect this number is around Mach .4 or about 450 feet per second, sience drag, and thereflore flow loss, is increases significantly after this.
Tube size can easily be checked by caluclating the maximum aireflow attainable, dividing that by the area of the tube in square feet, and dividing again by 60 to convert to feet per second. An approximate value for maximum aireflow can be obtained by muliplying the desired bhp by 1.5
Now devide this # by 1100 to give you the speed of air in the pipe. If its higher than .4 then increase the pipes ID, if its substainatly lower, possibly decrease the ID.
Corky Bell's Maximum Boost - Pg 62 Resist the temptaion to use larger diameter tubes than neccessary, as little drag is created in smooth tubes with gental bends. larger tubes will only add to the volume of the IC system, and that is not a good thing to do
-Jacob
Old Jun 23, 2004 | 11:12 PM
FB II's Avatar
corky bell is da man!
Old Jun 24, 2004 | 01:14 AM
maxcooper's Avatar
WWFSMD
There was a thread about this very subject not too long ago. I ran some numbers with Corky's estimated speed limit and even 2.5" pipes seemed big enough unless you are building a super-beast of an RX-7. I don't remember the numbers, but a quick search would surely locate the thread.
-Max
Old Jun 24, 2004 | 01:22 AM
sk8world's Avatar
Chasing numbers
Forgot I even had Corkys book.... I think 2.75 inlet to IC (So far that is the size I have been given of turbos outlet) and 2.5 or 2.75 ioutlet to TB....
Old Jun 24, 2004 | 01:40 AM
pinkfloyd's Avatar
not sure anymore
i just got that book. its great. I will have to do the math on that and post back with some #'s for you guys to go off of. This will be with a stock turbo though as i ran out of money.
Old Jun 24, 2004 | 12:32 PM
sk8world's Avatar
Chasing numbers
This will be used with Apexi FMIC, GT40R Turbo (if ever gets here) 16-18 psi for now. Once ported motor goes in then I will be running higher boost... The info I got from A-spec was 2.75 outlet on turbo. The IC has 2.5 in and out. Using Greddy elbow... ??????? What do you think?
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Jmolina0163
Oct 3, 2015 10:04 AM
