car wont idle so im guessing theres a vacuum leak, how to check for leak w/ no idle
Old Jun 22, 2004 | 08:46 PM
calio64's Avatar
finally finished up the FD UIM swap and car starts but wont idle, so how do i check for vacuum leaks if car wont idle? ive heard of using carb cleaner and spraying and were idle rises theres the leak but my car wont idle. or can i check anything else that would cause the car not to idle
any help would be appreciated
Old Jun 22, 2004 | 08:54 PM
gergrx7's Avatar
Boosting Again
get someone to hold the gas while you spray for leaks.
Old Jun 22, 2004 | 08:57 PM
calio64's Avatar
so what do i look for? will the rpms rise?
thanx
Old Jun 22, 2004 | 09:01 PM
PureSephiroth's Avatar
#1 Certified Cone Killer
yes, the rpm will rise and the idle will smooth out momentarily.
allforjesus06's Avatar
i love assembly lube
if you use some starting fluid and spray around, you'll notice a rise in rpms when you spray it over the leak.
Kyo
Apr 13, 2019 09:24 AM
alphawolff
Nov 17, 2015 05:57 PM
ncds_fc
Aug 15, 2015 10:06 AM
