charcoal canister ?
Old Jun 19, 2004 | 04:38 AM
Ol Fat Nuts's Avatar
charcoal canister ?
I'm ditching the canister, what is the best way to reroute the hoses?
Old Jun 19, 2004 | 09:31 AM
OtakuRX's Avatar
The Rotorheaded Geek
I just pulled it and forgot about it.
Old Jun 19, 2004 | 10:07 AM
mazdaverx713b's Avatar
Have RX-7, will restore
why are you ditching it? you will probably smell gas fumes and it will be intrusive. the thing weighs less than 3 pounds and it will do nothing for you to remove it. i advise against this.
Old Jun 19, 2004 | 10:55 AM
perfect_circle's Avatar
off topic: (a little) what does the canister do?
Old Jun 19, 2004 | 12:11 PM
I am trying to clean up my engine compartment and it is bulky and i am pretty sure i dont need it or the 10 ft of lines that come with it. should i just bypass it or capoff the metal fuel line and also the port where it enters the block?
Old Jun 19, 2004 | 12:53 PM
leave it in place. i suggest this. you will smell like gas. the charcoal canister traps fuel vapors and snuffs them. you might regret pulling it
Old Jun 19, 2004 | 01:19 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
go ahead and pull it. if you don't like the way your car smells inside, put it back.
Old Jun 19, 2004 | 03:22 PM
g prime's Avatar
Can those things die? I can smell gas in the cabing, not much but some.
Old Jun 19, 2004 | 03:30 PM
K-Tune's Avatar
FD Daily
ditch it, and move your vent line hose so that the fumes won't enter the cabin.
Old Jun 19, 2004 | 05:50 PM
ChunkyMonkey's Avatar
Clutchless in San Antonio
anyone have a pic of what it looks like/where it's at. I get a fume smell in my car while I'm driving also.
Old Jun 19, 2004 | 08:46 PM
Tom's Avatar
Tom
Whack 'em and stack 'em
From: Clarksburg/Bridgeport WV- North Central Appalachia
I would highly suggest that you do a search function on 'charcoal canister' in this section. There is a lot of good information on what it does, why it's there, and why it should be left alone.
It is more a function of the gas tank /purge system than anything else. It is important and rarely fails (unless your purge system is faulty elsewhere).
Old Jun 20, 2004 | 01:46 AM
rhinor61's Avatar
Well if you are going to pull it, then make your gas cap vented. A pressurized fuel tank system uses the charcoal to absorb the gasoline fumes. Fumes are created in the tank and under pressure they have to vent somewhere. In the old days you did not pressurize the tank, and they used vented gas caps.
Drill a small 1/8" hole in the gas cap.
NOTE: I do not defeat or recommend the removal of any emission device on my or any person vehicle that is operated on public highways.
J.
Old Jun 20, 2004 | 02:22 AM
Directfreak's Avatar
I am a Jeeper Now.
I removed mine, and regret it. My car is garage kept, and even when just sitting there, the whole garage will smell of gas.
I am actually going to fit another one back on the car, except I will mount in the rear by the fuel tank. - Like 3rd gens.
Old Jun 20, 2004 | 05:10 AM
cdrad51's Avatar
indicated by the arrow.
Old Jun 20, 2004 | 10:35 AM
RotaryRyan's Avatar
DSM
^^^wow, your engine is shiny new like sweet!^^^
Old Jun 20, 2004 | 12:26 PM
cdrad51's Avatar
lol thx, that's because it is new, well 1000 miles.
Old Jun 20, 2004 | 03:41 PM
OtakuRX's Avatar
mine clogged and was causing trouble, wouldn't vent anymore.
Old Jun 20, 2004 | 04:35 PM
is the larger hose on the c.c. venting out fumes from within the engine?
NotMrButts
Feb 10, 2018 06:36 PM
