what is a compression check?
Old Jun 16, 2004 | 09:02 PM
1989 GTUs's Avatar
what is a compression check? what compression is it checking? engine?
Old Jun 16, 2004 | 09:05 PM
KenshinFC's Avatar
LOL!!! Hahhahahahhaha....
i dont want to answer this one.. i'll just laugh...
Old Jun 16, 2004 | 09:09 PM
1989 GTUs's Avatar
thats messed man...im just trying to find out what it is. you shady...whatch when you going to need help with something in the future i hope sumone do the same to you
Old Jun 16, 2004 | 09:38 PM
KingCobraV9's Avatar
Rotary engine victory
yes a comprestion check checks the engine compression. lets you know what is going on inside the engine by the numbers it reads. lets you know if your engine is blown, gimped up, ok, running strong ect u get the idea.
Old Jun 16, 2004 | 09:41 PM
J-Rat's Avatar
Alcohol Fueled!
The compression number is an indication of the conditions of your seals.
Old Jun 16, 2004 | 09:48 PM
Project84's Avatar
Open up! Search Warrant!
Do you know how a piston engine, desiel engine or rotary engine works? To know what a compression check is, you need to know how an engine works.
Old Jun 16, 2004 | 09:52 PM
1989 GTUs's Avatar
pioton engine goes up and down, rotary spins, and i dont know anything about desiels
Old Jun 16, 2004 | 09:55 PM
well u need to read up on rotarys look around this excelent website and go to www.howstuffworks.com and find **** out about engins of all kinds otherwise knowing what it is will do you no good.
Old Jun 16, 2004 | 10:05 PM
S2-13BT's Avatar
Grab the basics from here:
http://www.rotaryengineillustrated.com
A compression check will let you know the condition of the engines seals. Considering that any engine is basically a big air pump, you need a well a sealed engine to get anything done. The better the engine is sealed, the better it'll run and the more efficient it'll be.
There are certain specs for compression, and if the engine is below par (for it's age or kms, sorry, miles ) then you might wonder what the deal is. Things like bad apex seals, or side seals etc. Low compression, can affect things like mpg, power, starting, and things like that.
So it's a first step when checking the health of a motor.
ZacMan
Sep 19, 2015 09:20 PM
BLK 93
11
Sep 9, 2015 10:56 AM
whinin
Sep 5, 2015 11:52 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
