boost sensor?
Old Jun 15, 2004 | 01:48 PM
HI!
Arrow boost sensor?
how do you know if it is going bad/ gone bad?
Old Jun 15, 2004 | 02:15 PM
WAYNE88N/A's Avatar
You'll get a code, for sure...But that thing throws codes all day in my car & she's still good...The FSM & Haynes manuals have procedures to check it, but what I do is put a meter lead on the ECU plug (don't have the schematics with me now, it's on page 4A-32 or so in the FSM), and drive around & watch it. It jumps all over the place, from about .5v to 3.5v, IIRC...You can also hook up a meter at the boost sensor itself & suck on the hose & watch the numbers, then check for the 12v & 5v at the proper pins/wires..See FSM/ Haynes...
Old Jun 16, 2004 | 12:26 AM
HI!
thank you
Old Jun 16, 2004 | 12:28 AM
Jaared's Avatar
Ahhhhhhhh hhh....
mine jumps all over... i installe a "orface" today... helped... but still doing it.
Old Jun 16, 2004 | 12:51 AM
HI!
would a bad press sensor cause a car not to idle?
Old Jun 16, 2004 | 12:52 AM
AcidShock's Avatar
Eet fase
An orifice, you mean? Basically a piece of plastic with a with a hole through the center that delays the air change that the boost sensor gets.
Old Jun 16, 2004 | 12:53 AM
AcidShock's Avatar
Eet fase
To the best of my knowledge it deals with acceleration and gasoline mileage. My boost sensor was bad and I did not have idling problems. However, acceleration felt very jerky until I replaced it.
Old Jun 16, 2004 | 08:01 AM
Jaared's Avatar
Ahhhhhhhh hhh....
you can see the jumping signal on my dyno sheet... guess its time for a new one.
rgordon1979
40
Mar 15, 2022 12:04 PM
AXA
Sep 5, 2015 10:06 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
gabescanlon
Sep 5, 2015 12:09 AM
