91 T2 issues
Old Jun 14, 2004 | 09:32 PM
eddierotary's Avatar
back with rotaries
91 T2 issues
a friend of mine have a 91 T2 and it starts, runs for a little time and quit and starts again but it quits. he change the AFM, and i check for cracks in the TID and theres nonelooked in the IC for cracks and nothing and i looks for any leaks and nothing. checks for leaks in the IM and nothing. have new spark plugs and wires so my question is what else to check? it have to be something that is making the car act weird. somebody had this problem before? thanks
eddie
Old Jun 15, 2004 | 04:53 AM
back with rotaries
bump
Old Jun 15, 2004 | 06:14 AM
SureShot's Avatar
Seduced by the DARK SIDE
It could simply be the idle setting.
If the basic idle bleed is too low, it will stall at the end of the warm up cycle.
Back up the idle bleed screw (on the BAC) & see if that helps.
Old Jun 15, 2004 | 11:33 AM
back with rotaries
but it doesnt rev up at all, you try to rev it up and back fires and quits. sorry that i didnt ad this but is that what is doing, even warmed up does that starts, revs up to 2k and stalls, try to rev it up and backfires and quit, i still havent check the timing but if that isnt whats else should i check?
Old Jun 15, 2004 | 12:12 PM
hondahater's Avatar
spending too much money..
does he have an safc? If he does you may want to restore back to factory defaults. Mine was doing that same thing and finally after checking everthing I reset it and bam!
Old Jun 15, 2004 | 12:25 PM
RotaryForce13B's Avatar
Check the on board diagnostics see what flash codes its giving you. I had a friend that had a 90 GTU that did that (run for a min then kill) and the flash code was a 37 (I think). That is the code for a bad oil metering pump. So, he swapped out the OMP and it still did it. Little did he know that the code is the same code for a bad computer. He swapped the computer and all of his problems were solved.
Old Jun 15, 2004 | 12:33 PM
back with rotaries
board dinostic? theres one on the FC?, were at? sorry for my ignorance but i didnt knew theres was one. and how to decode it? any website or the hayes book tells you?
Old Jun 15, 2004 | 12:38 PM
Here is a link to down load a factory service manual
http://www.teamfc3s.org/main/factory_service_manual/
Old Jun 15, 2004 | 12:44 PM
Here is another usefull link
http://www.teamfc3s.org/info/article...odes/main.html
Old Jun 15, 2004 | 05:56 PM
back with rotaries
roatryforce: is that last link, works with the 89-91 too or just the 87-88?
Old Jun 16, 2004 | 03:30 PM
back with rotaries
bump
Old Jun 16, 2004 | 04:08 PM
1SxyRXy's Avatar
my fc broke
maybe the AFM he put in is bad? try fo find another one if not that then check for vac leaks. make sure you plugged everything back in
Old Jun 16, 2004 | 09:53 PM
back with rotaries
is a bard new one, we been checking everything but without trying to get alot out thats why i wanna have the codes so i can figure out what the hell is wrong with it. somebody have the codes for the 89-91?
rgordon1979
40
Mar 15, 2022 12:04 PM
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
betes
Sep 27, 2015 08:25 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
