does the intake temp sensor have to be hooked up?
Old Jun 14, 2004 | 05:25 PM
calio64's Avatar
finishing the FD UIM swap, and the FC elbow had a little temp sensor screwed in it, my question is what exactly does this do? and does it have to be plugged in? im still going to be running the stock ecu.im hoping i dont have to tap into my greddy elbow for this sensor
thanx in advance for any info
Old Jun 14, 2004 | 08:39 PM
RETed's Avatar
The car will run rich and eat a lot of gas.
On average, it will run 10% to 15% less gas mileage.
-Ted
Old Jun 14, 2004 | 11:12 PM
calio64's Avatar
Ted,i have a plx wideband and a s-afc to tune with, so will this fix not having the sensor hooked up?
thanx alot the info is always appreciated
Old Jun 15, 2004 | 12:41 AM
NZConvertible's Avatar
I'm a boost creep...
The air temp sensor is there to compensate for changes in ait temps, something that happens a great deal with a turbo. You cannot do this with a fuel controller. Install the air temp sensor in the FD manifold's stock location.
Old Jun 15, 2004 | 12:14 PM
calio64's Avatar
sounds good thanx alot
Old Jun 15, 2004 | 06:24 PM
calio64's Avatar
can i use the stock FD sensor?
Old Jun 15, 2004 | 10:33 PM
RETed's Avatar
The sensor characteristics are significantly different.
The short answer is NO.
-Ted
Snoopy FD
Dec 8, 2015 01:45 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
