oil leak....
Old Jun 12, 2004 | 02:40 PM
thafox's Avatar
nother rican witha rotary
oil leak....
im pretty damn sure it's gear oil that's leakin....it's leaking right where the trans meet's the engine in the middle is there any way i could fix this without takin parts off? silicon mayb? or is that a bad idea?
Old Jun 12, 2004 | 03:51 PM
Jeff20B's Avatar
Lapping = Fapping
If it's dripping from where the bellhousing meets the rear engine plate, you'll need to determine what type of oil it is before you work to correct it. You said it's gear oil, so that means the tranny needs to be removed a gasket/seal kit installed. I've done it on an SA22C tranny ('79-'80) and it was not a problem. The '81-'85 slider hub casting is the same.
If you siliconed it up, oil would fill the bellhousing and destroy the clutch disk and starter.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
