Help in Deciding T04R
Old Jun 9, 2004 | 05:15 PM
Hi,
I have decided to buy the Big kahuna T04R from cheap turbo...
Can someone tell me the best specs i should order for a FD...
compressor: TO4R
.70 a/r
66.5mm inducer
flow: 75 lbs/min 960cfm
360* thrust bearing standard
turbine: T4
your choice of: on center housing: .58 a/r or tangential: .70a/r .84 a/r .96 a/r housing
available with 0 or P trim wheel
I will be adding a wet center section to it...
Let me know what i should choose
Also if i run the T04R at 13-15 psi for a little while will it be worth it?
thanks
Old Jun 9, 2004 | 05:27 PM
Crusader_9x's Avatar
i had there t04s then switched to the t04r and the defference is whether or not the tires are roasting in first gear. all depends upon what u wnat. but i could do it over afian i would ge the q trim wit the 96.
Old Jun 9, 2004 | 05:49 PM
I would choose the .84 if you can get a Q trim, otherwise the .96 P trim. Carl Byck
Old Jun 9, 2004 | 06:02 PM
Ok very new to the single turbo.. what would be the ups and downs of P and Q trim..
What if i go for the .96 Q trim or .96 P trim
I am very new so i am asking basic questions.. have to order asap..
thanks
Old Jun 10, 2004 | 01:43 AM
Infini IV's Avatar
Microtech Tuning!
.96 Q trim should yield greater exhaust flow, but slightly laggier turbo response...
.96 P trim should respond slightly quicker, but with slightly more restricted exhaust flow.
Old Jun 10, 2004 | 06:11 AM
what hp should i look at if i go for the above configuration on a mild streetport fd.. by restricted do u mean the car will choke up top? or just it cud be better..
I will be buyin the following turbo:
T04R .96 a/r p trim
wet center housing
what would be the spool-up and max hp..
thanks
Old Jun 10, 2004 | 05:34 PM
Infini IV's Avatar
Microtech Tuning!
Maybe I shoudn't have used restricted.. but it doesn't flow as much air per revolution as the Q trim does. However, it should make for more streetable turbo response.
T04R would probably make around 450rwhp at 15psi on a streetport FD... More if boost is raised... 500rwhp should be achievable at or around 20psi boost.
eplusz
15
Oct 7, 2015 04:04 PM
