Power FC Boost control KIt for powerfc
Old Jun 2, 2004 | 12:06 AM
xthaboy17's Avatar
I have a 3 bar sensor and the apexi solenoid and everything associated with controlling boost with powerfc. I was wondering if i can just run a Profec B and sell the the boost kit or do i need anything for it. I am confused. i have a single that has a 10 psi spring and i wanna run 14-15 psi hopefully Kan can tune it. Any old threads i couldnt find much thanks.
Old Jun 2, 2004 | 07:57 AM
duboisr's Avatar
Put in the 3 bar and the profec b . Take out the apexi solenoid .Go to the pim screen on the pfc controller and find option screen . Go to option five with no offset so the 3 bar will work . If you use option 1 the car will run very badly with back firing and other bad action . For more info just call S KAN .
Old Jun 2, 2004 | 08:17 AM
PVerdieck's Avatar
Hang on. From what I heard the two are different systems.
You can run either the Profec B, and the PowerFC, or run the PowerFC with its boost control kit.
That PowerFC is a 278 or 378 add on kit, it doesn't make sense to run both.
Old Jun 2, 2004 | 11:46 AM
xthaboy17's Avatar
thanks guys its making more sense now, So let me get this straight the 3 bar sensor will have to be used regardless if i have a profec B or not? And also the apexi solenoid and the other little things associated can be sold right? Thanks!
MoTeC
Sep 10, 2015 07:58 PM
