1600cc Secondaries with no Fuel Rail?
Old May 31, 2004 | 04:16 PM
MazdaRx7Racer4Life's Avatar
I AM A THIEF!! READ THE FEEDBACK SECTION!
I heard there a way to modify the bosch 1600cc injectors to fit the fc secondary fuel rail without having to upgrade to a new one. Is this so? The person that told me also linked me here but I couldn't make anything out from teh website.
http://bdc.genxracing.com/1600INJ/
Old May 31, 2004 | 04:26 PM
Falcoms's Avatar
kill it with BOOMSTICK!
The way he is showing involves switching the top of the 1600cc with the stock injector and using that in the fuel rail. I don't know how he expects it to work with the large overhanging flange on the top, but if it does, go for it
Old May 31, 2004 | 05:30 PM
Anyone else know anything about it? Anyone try it?
Old May 31, 2004 | 06:11 PM
boosted1205's Avatar
1600cc mod
http://home.mn.rr.com/linnihan/1600c..._injectors.htm
Above is a more detailed explanation. There are 2 floating around but the above explains it rather than just pictures. I hope this helps you guys or gals
Old May 31, 2004 | 06:18 PM
The only thing you do is cut off the plastic below the top o-ring. Very easy to do. What some people did was use additional o-ring with the one that came with the 1600cc. Safe guard against leak I guess. It's a good idea something I did as well.
Old May 31, 2004 | 06:25 PM
SwooshMan's Avatar
Old May 31, 2004 | 07:03 PM
Maxthe7man's Avatar
Freedoms worth a buck o'5
Drill the factory rail out to 17/32, approx 1/4 deep and the 1600's fit without modification..max
Old Nov 17, 2004 | 07:32 PM
Net Seven's Avatar
Is that only for s4 fuel rail or what? I have an s5 fuel rail and the actual part the injector goes into is 20/32 which would only leave 1.5/32 wall all the way around and would be very hard to get it to drill exact because a slight shift and there would be a hole.
Old Nov 17, 2004 | 07:45 PM
patman's Avatar
Resident Know-it-All
chill out...it has an o-ring... use a drill press and get it as best you can, and it will work fine.
pat
Old Nov 17, 2004 | 07:57 PM
Net Seven's Avatar
Im not concered about how "clean" or how straight I get it, its the wall is VERY thin the way it is, and I know the s4 rails are aluminum and thicker than the s5 steel rails.
astrum
24
Nov 15, 2017 08:44 AM
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
