Which wires does the ECU get it's power source from?
Old May 26, 2004 | 09:59 PM
dhahlen's Avatar
FD Under Construction =P
Alright, my ECU will not power on. Stock or Power FC, I have a commander and it wont turn on and the car will not start.
I am curious where the ECU get's it's power source from, which wires? That way I can trace them...
Old May 26, 2004 | 10:05 PM
LT1-7's Avatar
John
I'm trying to remember from when I rewired my whole car but here goes. I believe it goes from the curcuit open relay. From there it turns to a black w/white stripes wire to the ECU. Don't know if this is totally accurate but find that black and white wire. If it doesn't show a 12+ then you've narrowed at least something down
Old May 26, 2004 | 10:07 PM
LT1-7's Avatar
John
try the black w/white stripes wire. That wire goes from the open curcuit relay to the ECU. That's the wire I used when rewiring my whole car.
Old May 26, 2004 | 10:47 PM
dhahlen's Avatar
Well I know there are about 3 wires in which it gets power. There is a constant to keep the memory powered, there is the power line which turns on the computer when the ignition is activated, and there is one more.
Is this black cable with white stripe the constant? Or the one after the vehicle has been turned to the "ON" position?
Old May 26, 2004 | 10:48 PM
I want to say it is pin B1 on the ECU, it is a black wire with white stripe. I think it is fed from the main fuel injection relay. Don't quote me on that though.
streetlegal?
Mar 17, 2022 02:46 PM
The Shaolin
Sep 14, 2015 07:50 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
