What turbo is this?!?
Old May 26, 2004 | 07:05 PM
ReDLiNe@t9's Avatar
Question What turbo is this?!?
i am interested in this turbo. The specs the guy told me on it was that it is Garret Based 4" inlet and 2 1/2" outlet with a 2.32" compressor, a 2.35" turbine and a .96 hotside housing. Does anyone know off hand what type of turbo this is or what other turbo it could be equilvilant to. Or by the numbers given the estimated amout of hp it can produce at a given amount of lbs?
Old May 27, 2004 | 12:03 AM
Infini IV's Avatar
Microtech Tuning!
Is the 2.32 compressor wheel inducer or exducer?
Don't hold me to it, but I'm pretty sure he's talking about a T04S (60-1)... The T04S should flow enough to support near ~450rwhp on a streetported 13b. There have been several people who have dynoed 400rwhp at 15psi on a streetport, and someone dynoed 380rwhp on stock 13bt ports.
Old May 27, 2004 | 01:31 AM
ReDLiNe@t9's Avatar
is what im looking at big enough to make high 10s-very low 12's?
Old May 27, 2004 | 01:32 AM
ReDLiNe@t9's Avatar
or in other words cam the to4s make times times like that.blah blah assuming its a properly tuned rx7 with all the required mods///
Old May 27, 2004 | 01:50 AM
$150FC's Avatar
Currently Winning
That is a pretty big range, but with 400rwhp you will run high, maybe mid 11s.
Old May 27, 2004 | 01:26 PM
ReDLiNe@t9's Avatar
do you think its worth buying the kit the guy is selling? It comes with the turbo i sed up top... downpipe with v-band....oil line block off plate 38mm tial wastegate and an obx manifold for 15000......keep in mind i want a street car and i wana go crazy f-ing fast.......i do have a stock motor with high miles but im ready for a street port if i need one soon.---he sed it will make 450hp at 20psi....
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
