Can someone look at this PIC and identify a part for me?
Old Nov 8, 2001 | 01:54 AM
ROSHX7's Avatar
http://k2rd.freeservers.com/cgi-bin/.../TPS/tset1.jpg
That SPRING located right beneath the yellow drawn in ARROW, is that the one to REMOVE so that when you do the TPS adjustment, its not affected by the THERMOWAX system?
Old Nov 8, 2001 | 03:23 AM
ROSHX7's Avatar
Also that screw the yellow arrow is pointing to, what the HECK is that for???
Old Nov 8, 2001 | 06:47 AM
Sniper_X's Avatar
Okay.....
You need to get the factory service manual off the web.
the '88 maunal will be fine for now....
http://www.iluvmyrx7.com/Technical_I...ice_manual.htm
BUT the screw you speak of is the master set screw.
Dont mess with it.
The spring is also not to be messed with.
Its the return spring.
The manual will show you how to adjust the TPS properly.
Dont go on the heresay you get from everyone until you read the right way first.
Then compare the shortcut advice you get to that in the manual.
when in doubt, RTFM.
David Hayes
13
Sep 5, 2022 12:45 PM
82streetracer
Aug 23, 2015 09:28 AM
