What to block all the extra nipples with
Old May 25, 2004 | 11:00 AM
Indo Audio's Avatar
I am in the process of my single conversion, but all the extra nipples in the LIM/UIM what do I use to block them efficiently? Also what did you all use as gaskets for your block of plates?
Thanks so much,
Ravi
Old May 25, 2004 | 11:31 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Go to autozone to the "HELP!" section. There's a bunch of different vacuum caps to choose from. Just get a couple of the sets with different sizes..
As for the LIM, there is only 1 vacuum line you will need to cap. It's the one by the front of the secondary fuel rail. Other than that, theres only the one to the FPR. The 4 on the inside and outside are the same. Just tubes that route through the LIM. No need to cap.
Old May 25, 2004 | 08:00 PM
Indo Audio's Avatar
Thanks so much I appreciate it.
Old May 25, 2004 | 08:41 PM
RX794's Avatar
NYC's Loudest FD
I would just weld the holes shut, if you run high boost, you're likely to have the plugs pop off. Same thing goes for people using block off plates, they may leak under boost.
Old May 25, 2004 | 09:58 PM
tkuwaha's Avatar
I had to cap off quite a few nipples on the UIM since I took pretty much everything off under UIM(ACV, emission solenoids, double throttle, AWS, ISC, etc.) I just cut short pieces(~2") of vacuum hose and bridged adjacent nipples in pairs. This way, both ends of silicon hose sees the same pressure even under high boost so there is little chance of hose popping off. If you were using the "Help" rubber caps, I would recommend using silicon gasket material and zip tie so it would not pop off under boost.
24seven_dada
20
Nov 10, 2018 12:03 PM
NotMrButts
Feb 10, 2018 06:36 PM
maikelc
Sep 24, 2015 01:01 PM
t-von
Sep 10, 2015 01:56 PM
