searched...runnin rich
Old May 24, 2004 | 02:15 PM
esebueno's Avatar
well...as stated, my cars runnin rich ( i know rich is better than lean...but its still wasted gas and with these prices....)
car's a non-cali runnin with a cali ecu (borrowed my friends to get my car home)
its throwin out the egr code (code 16).
IF i get a non-cali ecu (cant afford PFC yet)...will that fix the rich prob?
everythin else is pretty much new...injectors, engine (reman), turbos, vacuum lines...etc
thanks!
(side question...there are 4 bolts connecting the top of the precat to the motor, right?)
Old May 24, 2004 | 02:25 PM
TracyRX7's Avatar
FD = Mr. Toad's Wild Ride
The stock ECUs all run "rich". There is a thread about this in the Advanced Tech Section ( https://www.rx7club.com/showthread.p...hreadid=308996 ).
And yes there are 4 bolts connecting the top of the pre-cat (the top left bolt facing the car from the passenger side fender is hard to see). For more information search for stuff on downpipe installations.
Old May 24, 2004 | 02:46 PM
esebueno's Avatar
ah...so there's not really that much i can do about it :/
Old May 24, 2004 | 02:49 PM
Mahjik's Avatar
Mr. Links
What exactly is the problem? Is it just that you can't pass emissions?
Are you getting a lot of fumes from the exhaust or in the cockpit?
Old May 24, 2004 | 04:14 PM
esebueno's Avatar
that "rich" smell from exhaust and a/f meter sayin its runnin pretty damn rich
didnt know all FDs ran super rich...now i do
Old May 24, 2004 | 04:17 PM
Mahjik's Avatar
Mr. Links
Well, the A/F gauge is really only (semi) accurate at WOT unless it's using a Wideband O2.
The rotaries have a little more "exhaust smell" than your typical piston car even in stock form. However, if it's excessive (and you still have the main cat), something could be wrong.
Old May 24, 2004 | 06:01 PM
esebueno's Avatar
ah...no main cat...guy at the shop said throwin the midpipe on would lean it up!?
(main cat might be bad tho...had that kinda "foul" smell when we put it on...so it went off)
ill go look for another cat
thanks mahjik
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
WyomingTII
Sep 28, 2015 10:32 AM
Captain Hook
Sep 22, 2015 01:12 PM
