Oil injector clearance issues with braided fuel lines
Old May 20, 2004 | 08:08 PM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
Question Oil injector clearance issues with braided fuel lines
Ok. So I've recently upgraded to -6 braided lines. There is an issue with clearance on the primary rail's outlet fitting and the oil injector under it. It's basically hitting it, and, of course, I didn't find this out until after the fact and split the weld (fittings on stock rail).
Does anyone have the same setup that's still running with the metering lines?
If so, what did you do to overcome that?
Thanks!
Old May 20, 2004 | 11:56 PM
GoRacer's Avatar
Speed Mach Go Go Go
I have Goodrich SS braided oil metering pump lines but I don't really understand what you have or what you're doing or what you're asking. ...you talkin bout fuel lines?
Old May 21, 2004 | 12:32 AM
CCarlisi's Avatar
Rebreaking things
I had the same problem. I have -6an ss lines with russell fittings threaded into the stock primary rail.
I tightened the fitting down a few turns and there is now enough room for the rail, however the fitting still makes contact with the rear oil metering nozzle. The next time I have the fuel system out I am going to remove a 1/4" or so of thread from the outlet hole so that the fitting will not stick out as far.
Old May 21, 2004 | 02:57 AM
rex u.k's Avatar
I have -8 lines on both rails, the primary rail fitting makes contact with the oil injector but still went on , no leaks.-8 fittings are a fair bit bgger than -6.
You should have zero problems with -6 fittings,you are not using the right fittings if your -6 ends are touching the injector.
i
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
