replacing alternator pully
Old May 20, 2004 | 04:05 PM
lemonade's Avatar
You can choose this?
i replaced my alternator with one from a 2nd gen, but its pully is too small. i want to replace it. i think a right sized belt would be hard to find. i cant get the bolt off, its on there too tight. and i cant stop the pully from turning with the bolt well....anyone have any good ideas?
also, should i find a belt thats the right size? i just have one belt. it goes from the e shaft, by the oil pump, and to the alternator. if i get one thats a little small, can i just lower it on that angle thing so it fits tightly??
Old May 20, 2004 | 04:21 PM
two words:
Impact Wrench
Old May 20, 2004 | 04:42 PM
Bob Holton's Avatar
recycled teenager
three words ; go for it
Old May 20, 2004 | 05:33 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
Originally posted by Rutnick
two words:
Impact Wrench
That will do it. Took mine off the other day to put a double pully on.
ON a side note. Just go to the parts store and get a shorter belt. Put it on in the parking lot and change it if it is not short enough.
Old May 20, 2004 | 07:11 PM
rhinor61's Avatar
Ok, why not put on the pulley from the orginal alternator. Impact will not that right off, I would avoid using a smaller diameter pulley, since the alternator will be making more revolutions per RPM. Thus robbing you of HP and over running the alternator. GO larger pulley if you run at high RPMs like in racing, but do not go smaller that OEM diameter.
My 2 cents.
J.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
Apoc3D
Sep 5, 2015 10:24 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
