Fuel pump position
Old May 18, 2004 | 06:54 PM
RotaryRyan's Avatar
DSM
Question Fuel pump position
OK, my other thread didnt work so....
I just bought a carter fuel pump and it has an up arrow on it.
Do I need to install it with the arrow up, or can it be sideways?
Old May 18, 2004 | 07:11 PM
Jeff20B's Avatar
Lapping = Fapping
Tenchi Muyo!
Old May 18, 2004 | 08:13 PM
RotaryRyan's Avatar
DSM
hmmmmm. that doesnt help me. but okay
Old May 18, 2004 | 08:33 PM
Rx7carl's Avatar
Airflow is my life
No, it must be installed correctly. The motor windings are designed to sit in the gasoline (it cools them). The pump wont last if you mount it sideways. Dont let anyone tell you differently.
Old May 18, 2004 | 08:36 PM
elwood's Avatar
I think any fuel pump that has an external motor should be mounted with the motor up. To verify, call Carter. I know this to be true of Holley and Mallory because I did call and check with their tech reps. The reason is that the pump housing may leak some fuel. If the motor is mounted so fuel can get near the brushes, a spark from the brushes could cause a fire.
Old May 18, 2004 | 08:43 PM
Jeff20B's Avatar
Lapping = Fapping
What I meant to say is mount the fuel pump in the direction indicated by the arrow on the label (in other words, this side up).
Old May 18, 2004 | 08:52 PM
Siraniko's Avatar
RX for fun
it has to be mounted upwards only...that is with the elecrical terminal facing down.
FYI: there are 2 types of carter pump....5 PSI and 7 PSI. with the 5 PSI, you dont need a fuel pressure regulator.
Old May 18, 2004 | 10:31 PM
RotaryRyan's Avatar
DSM
alright ill mount it with the arrow pointing up. Tanks for the help.
Queppa
Nov 18, 2024 03:47 AM
Skeese
65
Mar 28, 2017 03:30 PM
86glxNA
Aug 22, 2015 08:54 PM
