Stock Wastegate questions
Old May 18, 2004 | 05:26 PM
AFSOC_Commando's Avatar
I have a series 4 turbo currently installed. I am getting crazy boost up to 12-14 PSI with a ported wastegate.
My question is this, I have a series 5 Turbo to install that is ported.
I want to run about 5 PSI for day to day driving and use my Apexi AVC-R to raise it to about 10-12 PSI when I wish to get on it.
Since the stock wastegate for the S5 is set for 8PSI can I use the wastegate actuator/diaphram from the S4 to lower the boost level?
My mods are listed below to assist in helping me.... Thanks in advance!
S4 TII J-Spec
550 Primaries and 680 bsecondaries
No emissions or rats nest
80MM downpipe back CorkSport echaust
3 Inch custom TID with HKS Filter
SAFC
AVC-R
Walbro 255LP Fuel Pump
Open Air BOV
Crane HI-6
LM-1 Wideband O2 sensor and datalogger
Currently under hard load at 12 PSI I am getting around 10.4/1 AFM so I am sure the mix is rich enough, just don't like having any control over boost, removed AVC-R to make sure it wasn't effecting boost control and the boost is staying the same...
Thanks!
Old May 18, 2004 | 07:16 PM
Infini IV's Avatar
Microtech Tuning!
Both S4 and S5 wg springs are the same... 5lbs. The reason S5 TII's get 7lbs stock boost is because there is a factory boost controller that raises boost. However, your car is an S4, so when you put the S5 turbo in a stock S4, boost should still be at 5lbs.
Old May 18, 2004 | 08:25 PM
Awesome, Thanks for the info!!
C. Ludwig
Jan 30, 2019 06:31 AM
Jmolina0163
Oct 3, 2015 10:04 AM
