air fuel ratio
Old May 16, 2004 | 12:52 PM
pimpncuba's Avatar
Replaced the Displacement
air fuel ratio
took my plugs out today and they were really black. how do i adjust my air fuel ratio to run more lean in a 84 gsl-se? thanks
Old May 16, 2004 | 01:15 PM
RotaryRyan's Avatar
DSM
my plugs are always really black after awhile.
Old May 16, 2004 | 01:23 PM
Jeff20B's Avatar
Lapping = Fapping
Replace air filter. Also upgrade to direct fire ignition (no carb mods required lol).
Old May 16, 2004 | 08:24 PM
madsci's Avatar
How's the fuel economy?
Might want to check your oxygen sensor.
There's an adjustment for idle mixture, but shortly off idle I think those cars run closed loop.
Old May 16, 2004 | 08:34 PM
Jeff20B's Avatar
Lapping = Fapping
Ask j9fd3s. His GSL-SE recently had a problem with the rear injector. Also check the AFM.
Old May 17, 2004 | 12:45 AM
riceburner1r2001's Avatar
screw direct fire n the long run its going to f--- your car
Old May 17, 2004 | 01:18 AM
Directfreak's Avatar
I am a Jeeper Now.
Replace your O2 sensor.
Old May 17, 2004 | 02:10 AM
Jeff20B's Avatar
Lapping = Fapping
lol it was a joke anyway. Heh, carbs. Fix it and then go direct fire.
Old May 17, 2004 | 05:42 AM
REVHED's Avatar
Hunting Skylines
Eh? Care to explain exactly how it will "**** your car" and why all Rx-7's 86 and onwards run direct fire from the factory?
Old May 17, 2004 | 11:55 AM
Jeff20B's Avatar
Lapping = Fapping
I don't think that's what he meant. There are enough pro-direct fire threads right now to make him look like an idiot all on his own (if that's what his intention was).
Like I said, fix it and then go direct fire.
Old May 17, 2004 | 11:58 AM
j9fd3s's Avatar
Community Builder
working 02 sensor!
oh and to add fuel to the fire the rx8 has 1 coil for each plug.....
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
alphawolff
Nov 17, 2015 05:57 PM
