Sandblasting a oil cooler/ Radaitor
Old May 15, 2004 | 11:14 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
I have access to a good blast cabnet with adjustible air pressure. Would this be a good way to clean a cooler or Rad? would it hurt any of the parts? anyone else ever do it? I want to clean the Exterior and the Fins.
thanks
Old May 15, 2004 | 11:45 PM
AsburyD's Avatar
I wouldn't do it, you could probably get away with cleaning the tanks, but stay away from the fins they're made of very thin copper or brass and the air pressure required to blast would only bend the fins.
Old May 16, 2004 | 01:07 AM
rxtasy3's Avatar
DITTO. doing the oil cooler should be fine since it's aluminum and the tubes r much thicker. only do the tanks and mounting brackets on the rad if u insist on blasting it. the tubes on the rad r too thin and u'll blast right thru. a rad repair shop will clean them just fine, provided they also repair the aluminum rads too. i used to do rad repair. the solution used to clean the alum ones does a really good job, just make sure they flush it out really good and u let it dry thoroughly inside, use compressed air to get as much water out as possible.
Old May 16, 2004 | 10:49 AM
JIMMY54's Avatar
GSL-SE PRO
#1. material too thin, will warp and cave in
#2. consider those fins destroyed
#3. getting any sand in the oil cooler will destroy you motor and it will be imposible to get the sand out.
Better off just getting a new rad, and cleaning your oil cooler with a solvent.
Old May 16, 2004 | 01:00 PM
agentorange's Avatar
'82 GSL '05 SRT-4
a radiator or cooler is the last thing you want to put in a blaster... it would eat up the metal like popcorn no matter what pressure you put set it at. Just like Jimmy54's first line... METAL TOO THIN!!!!!!!
Unless you want Swiss cheese for a cooler.
Old May 16, 2004 | 02:16 PM
Hades12's Avatar
Have any of you done it before? Or is this just what is thought?
Old May 16, 2004 | 03:05 PM
Manntis's Avatar
add to cart
one guy posted a pic about a week ago with zig-zag lines in his radiator - just from pressure washing it with water on 'pencil' setting. If a water pressure washer can do that damage, imagine what blasted sand would do.
Old May 16, 2004 | 04:34 PM
rxtasy3's Avatar
as i said in my other post, i've worked in radiator repair. the only time we sand blasted was to the tanks and brackets on the copper rads when doing a recore.
Old May 16, 2004 | 06:19 PM
Hades12's Avatar
Ok. Sounds like it is a bad ideal. Guess I will just use some degresser to clean the fins and a drimmel to clean it up and repaint the tanks.
I Have a bad core, So I may try it someday, just to see.
thanks to everyone.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
