New Custom Intake setup :)
Old May 11, 2004 | 10:00 PM
coldy13's Avatar
Yeah, shutup kid.
The pics and small description are here:
http://www.cardomain.com/memberpage/396921/3
The manifold and hat were made by me, welding done by mid-ohio products.
Old May 11, 2004 | 10:02 PM
r0tary noob's Avatar
nice setup
RotaryRyan's Avatar
DSM
That looks Really nice.
Old May 11, 2004 | 10:03 PM
nice
Old May 11, 2004 | 10:27 PM
Max7's Avatar
Admitted Sevenaholic
Very Nice !
Old May 11, 2004 | 10:41 PM
Gregs's Avatar
make me one coldy
how much
Old May 11, 2004 | 10:48 PM
BrianHeston's Avatar
Beware Of Squirrely Wrath
sweet lookin setup...
Old May 11, 2004 | 10:56 PM
coldy13's Avatar
Yeah, shutup kid.
Hmmm, not too sure how much I would charge to make one. I'll have to see how it works on my car and see if there's anything I'd like to change before I start selling them.
Old May 12, 2004 | 12:43 PM
coldy13's Avatar
Yeah, shutup kid.
There are vacuum fittings on it now, just didn't have 'em on yet in these pictures. I'll get some pics of it on the engine in a week.
Old May 12, 2004 | 12:48 PM
mwatson184's Avatar
holley guy
Looks good coldy, car should be running in about a week?
Old May 12, 2004 | 12:55 PM
coldy13's Avatar
Yeah, shutup kid.
Should be. Engine in there is fucked. Taking it out tomorrow, tearing that engine apart firday, building the new one saturday, putting it back in sunday. Hopefully I'll be driving in monday and be tuning it all next week.
Old May 12, 2004 | 01:17 PM
Directfreak's Avatar
I am a Jeeper Now.
Looks real good. Seriously Nice Fabrication skills.
My one recommendation:
Make the Charge Air inlet on the top or bottom of the air box. you have it pointing straight into the carbs, and unless it's "PERFECTLY" centered, one side might get more airflow than the other.
Which I am sure you already know can lead to tuning problems, leaning out, etc.
If the pressurized air points away from the carb inlet, then the whole box will be pressurized, and you'll have even flow into the carbs.
Old May 12, 2004 | 09:56 PM
coldy13's Avatar
Yeah, shutup kid.
Well, all the holes were cut on a prototrack mill, so it's "prefectly" centered as much as it can be, probably easily within 1/32".
Also, no room on top or bottom to do it. Hood doesn't clear by much at all. And on the bottom I already had to chop off 1/2 the oil filler neck to give it clearance. I made the runners long to give it more low/mid power and the turbo hat would hit the filler neck if it was stock heigth. You'll see exactly what I mean once I get pics of it on the car.
Old May 13, 2004 | 07:04 PM
peejay's Avatar
Old [Sch|F]ool
Neeeeet.
You might want to redo the hat. It looks *way* too small. You want room for velocity stacks on the carb (velocity stacks are almost a MUST for sidedrafts) and then maybe as much length again as the stacks take up.
I realize that clearance is an issue.
Old May 13, 2004 | 07:23 PM
d0 Luck's Avatar
raysspl.com
wow! props for such a clean job!
... but how bout 'em 48 IDA intake manifold and hat??!?!
Old May 13, 2004 | 07:48 PM
coldy13's Avatar
Yeah, shutup kid.
Originally posted by peejay
Neeeeet.
Yeah, I want to make a bigger one that will let me use the stacks, but for now this one will work. I took care of clearance with the oil filler neck, I just cut most of it off So now I should have room for one that's quite a bit bigger.
Old May 13, 2004 | 07:50 PM
coldy13's Avatar
Yeah, shutup kid.
I could make them, but I'd have to be able to borrow an IDA from someone so I could make sure everything would fit.
Old May 14, 2004 | 04:52 PM
jorx81@aol.com's Avatar
Still Dreams of 3rd Gen
Trim down that carb flange!
did you just buy mandrel u-bends from somewhere?
or.....what are they?
How thick are the pipes?
I guess you just bought the intake (engine side) flange?
If so I can make you those flanges for way cheaper than rb or whoever.
Let me know.
Old May 14, 2004 | 07:48 PM
agentorange's Avatar
'82 GSL '05 SRT-4
If your worried about your clearance you might want to thing about fabricating a hood scoop.
nice job too!!
Old May 14, 2004 | 07:49 PM
'82 GSL '05 SRT-4
hood scoops are really easy, especially since you can do that!!
Old May 14, 2004 | 07:56 PM
Manntis's Avatar
add to cart
carporn
Old May 15, 2004 | 12:26 AM
coldy13's Avatar
Yeah, shutup kid.
Let me know.
I didn't buy racingbeat flanges, I made them myself. And I just got 4 u bends and cut them and merged them myself. Pipes have a 1/16 wall I think.
Old May 15, 2004 | 07:51 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
That's a fantastic job, cody.
I'll be interested to see what it will cost.
I hope people will understand that quality work like that isn't cheap.
Old May 15, 2004 | 08:07 AM
Sterling's Avatar
Cody are those photographs reversed?
From the photos, the mani looks like it's sloping the wrong way.
Old May 15, 2004 | 08:57 AM
Unsupa's Avatar
Blew my 3rd one 12/8/08
Great work Cody..
not sure what ya mean by sloping Sterling, but they look good to me..
I think your next project should be an intake manifold for the stock carb so that turbo clearance problems will be taken care of. Surely I wouldn't be the only one interested, once i get the cash to actually go turbo..
