Engine Died on me....overhaul in order....need help
Old May 11, 2004 | 01:08 PM
JCORMIER12345's Avatar
Ok, here's the deal. The other day my engine started sputtering while driving down the road. It felt like I had about half the horsepower and I didn't have hardly any throttle response. I limped home and pulled the plugs. The leading and trailing plugs from the front rotor were fine. The Trailing plug from rear rotor was fine as well. The problem lies with the Leading plug in rotor #2. It was full of oil and looked black and "killed". I replaced it and the rest of the plugs and started the engine for about 3 minutes. After about 1 min. no more blue smoke from the tailpipe but still very rough idol. After the 3 min. were up and the idol still not at all what it should be, I checked the two leading plugs to compare them. Rotor plug #1 was fine, rotor #2 had some oil on it......Conclusion: A blown apex seal. Am I correct in my assumption? If so, I need to rebuild the engine...which I am not affraid to do. I have a 13b with EFI in my '85 GSL-SE. Now, I have heard some horror stories from some guys around here about carbing the engine...with all the tweaking and tuning they need to do. I want to know if I can get as much horsepower, when I rebuild, with the efi unit as I would with the carb, as well as get your opinion about which is easier to install a turbo with. I know this is a long thread, but it will let me get a good start on my project car. I will check the other threads on this page concerning the particular questions I have asked you as well. Thank you all in advance for your help and educated answers.
Justin
Old May 11, 2004 | 01:13 PM
wwilliam54's Avatar
it WILL run
yuh blown seal
there is a good rebiuld shop near you IIRC
someone to talk to in person helps with probs alot IHMO
Old May 11, 2004 | 01:40 PM
What is the name of the rebuild shop? Is it IIRC?...
Thanks for the response bud.
Old May 11, 2004 | 01:42 PM
wwilliam54's Avatar
it WILL run
IIRC= If I Remeber correctly
im trying to remneber
its rotrary rebiulding or something
Old May 11, 2004 | 01:46 PM
What state?, Town, I can look it up from there I think. Hey...what's your opinion on what type of porting I should use if I want to turbo my 7 and run it mostly as a fast as shi% car on the road?
Old May 11, 2004 | 01:49 PM
85rotarypower's Avatar
love the braaaap
A blown apex seal would lead to bad idle as you mentioned, but not to the oil soaked plugs on the rear rotor as mentioned. My guess is that the oil seals are gone. This would let excess oil into the rotor housing causing the air/fuel mixture to get diluted with oil and cause oil soaked plugs and a rough idle. Either way it needs a rebuild.
For more power, I would suggest porting your engine. This is pretty much the most effective way to increase HP on your car without going to forced induction.
Old May 11, 2004 | 01:50 PM
coldy13's Avatar
Yeah, shutup kid.
I'd go with a large streetport on the intake, and a huge exhaust port.
Old May 11, 2004 | 01:51 PM
wwilliam54's Avatar
it WILL run
i think they are in knoxville tn
Old May 11, 2004 | 01:52 PM
love the braaaap
Damn slow typing fingers!!!!
Coldy knows best. Weren't you the first one to make a custom turbo setup for a 12A?
I would also suggest using the turbo from a TII.
Old May 11, 2004 | 04:19 PM
Xavier8's Avatar
Never satisfied
If you find the name of the good rebuilder in Knoxville, please tell us. I might think about getting my 12a done there if they are a good rotary shop.
Old May 11, 2004 | 06:11 PM
Yark79's Avatar
Are you thinking of Rotary Resurection? I'm pretty sure they are in Morristown.
Old May 11, 2004 | 06:58 PM
riofrio's Avatar
This IS a tasty burger!
Yeah it's rotary resurrection. The name of the guy is Kevin Landers and supposedly he's pretty good and offers very fair prices. Check out the website, http://www.rotaryresurrection.com, it should answer all your questions.
Old May 11, 2004 | 07:30 PM
wwilliam54's Avatar
it WILL run
thx
Old May 11, 2004 | 08:02 PM
love the braaaap
I wish I had the money for a rebuild. If my engine went out or had any major problems, I would be done with this car. I would have to park it. I just don't have the money for a rebuilt or even used engine right now. Consider yourself lucky.
Old May 11, 2004 | 11:29 PM
wwilliam54's Avatar
it WILL run
same here, but with a blown engine already
Old May 13, 2004 | 05:16 AM
Again, guys...thank you for your help and knowledgable input.
Old May 13, 2004 | 01:23 PM
uRizen's Avatar
XBL** Ownicus
I was looking at a couple of FCs that had blown engines and was thinking of picking one up (one guy is trying to get rid of a GTU with a good body and interior for ~$500) and then rebuilding it for a fun little side project. I was going to snag the basic rebuild kit and the bideo they sell at www.rotaryaviation.com, but was wondering how hard it is to do a basic street port at the same time. Are there any guides that show how to do it?
Old May 13, 2004 | 01:30 PM
r0tary noob's Avatar
go to www.mazdatrix.com, they have templates i believe www.atkinsrotary.com does too, but you can also take the engine toa rotary repair shop and pay them to do it for you, knid of a waste of money in my book, but too each his own
Old May 13, 2004 | 01:34 PM
coldy13's Avatar
Yeah, shutup kid.
Nah, there were quite a few before me. Most of my first setup(blowthru nikki, no IC) came from RotaryShack. This new setup has lots of my own custom parts though.
I think it's easier to do a turbo setup using a carb. You'll get a bit more HP and streetability with EFI, but it'll also cost a lot more.
Old May 13, 2004 | 01:53 PM
uRizen's Avatar
XBL** Ownicus
From what I've seen of the porting it didn't look too complex to me. You're just making the intake ports larger without digging into the coolant seal area, right? Atkins didn't have a template from what I could find, but here's the page on porting I found on Mazdatrix:
http://www.mazdatrix.com/faq/porting.htm
It looks like 6 port engines really can't gain much by porting though, and all the NA FCs are 6 port, right? (I don't really plan on a TII).
Old May 13, 2004 | 01:55 PM
uRizen's Avatar
XBL** Ownicus
If you turbo with a carb instead of EFI, you don't have to play with an ECU to get the proper fuel delivery, since the carb will automatically compensate, right?
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
rotor_veux
Aug 23, 2015 09:06 PM
86glxNA
Aug 22, 2015 08:54 PM
