oil gage .....not the temp
Old May 11, 2004 | 11:19 AM
thafox's Avatar
nother rican witha rotary
Question oil gage .....not the temp
was readin a lil past 110 after i rode around for an hr also when i turned it on it was shakin a lil i checked the oil an it smelled like gas a lil ....wha's goin on?
Old May 11, 2004 | 12:04 PM
nevarmore's Avatar
110 is too high. There is a blockage in the oil system somewhere.
What does the oil look like? Golden brown or is it darker?
When was the last time it was changed?
What viscosity do you use?
Old May 11, 2004 | 12:21 PM
thafox's Avatar
it's golden brown....but i also heard a hissin noise on the passanger side of the engine....im going 2 change it soon mayb sunday
Old May 11, 2004 | 02:09 PM
nevarmore's Avatar
Track that hissing noise down. It's likely an unrelated vacuum leak, but it could be an oil leak. I'm still kinda new to the old 12a, are there any vacuum lines that could cause an oil issue?
Also, check the wiring and oil pressure sensor. There have been a few posts around here where there was a loose/broken/shorted/pinched wire that led to an unusual sensor reading.
Old May 11, 2004 | 09:30 PM
thafox's Avatar
no it's a 13b .......that hissin noise doesnt happen ne more but that gage does i hope it's just a wire thnx
Old May 12, 2004 | 07:02 AM
jimmdog's Avatar
Dude, Same THing happened to me this week end. The oil pressure started out a little high but once I got in to the Interstate it went all the way up. Turns out I had a bad OPSU hope that is all you have wrong. Good Luck
Old May 12, 2004 | 10:14 AM
thafox's Avatar
how do u check it? i hope it is also ....thnx
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
Jmolina0163
Oct 3, 2015 10:04 AM
