Are wastegates suposed to let a little exhaust out at idle?
Old May 11, 2004 | 05:51 AM
c00lduke's Avatar
like the title says, mine has a little coming out of it at idle, is it supposed to?
Old May 11, 2004 | 07:24 AM
Sponge Bob Square Pants's Avatar
A wastegate only lets exhaust out at or above a pre-set boost level. Your engine would not be making ANY boost at idle, and therefore no, the wastegate should stay completely closed.
Old May 11, 2004 | 10:06 AM
rxrotary2_7's Avatar
you must have the lines mixed up or running a vacume source rather than a boost source....
Old May 11, 2004 | 11:23 AM
sub-zero's Avatar
The valve might not be seated properly if it is worn.
Old May 11, 2004 | 12:58 PM
$150FC's Avatar
Currently Winning
gasket between the manifold and the wastegate might be gone?
could just be a bad BOV too, like subzero said,
Old May 11, 2004 | 02:03 PM
$150FC's Avatar
Currently Winning
Er, wtf. Wastegate, not BOV.
Old May 13, 2004 | 03:28 PM
Sidestick's Avatar
When I first installed my XS T04E kit, the wastegate was leaking at idle. Apparently the valve wasn't seating properly as it stopped after driving the car alittle bit. Guess it needed to be 'broken in'.
Old May 13, 2004 | 04:29 PM
c00lduke's Avatar
Mine is a HKS Racing Wastegate, are there any adjustments i can do or sent it off to get rebuilt?
Thanks
~Luke
Kyo
Apr 13, 2019 09:24 AM
Skeese
65
Mar 28, 2017 03:30 PM
85TIIDEVIL
Aug 25, 2015 12:09 AM
Engine stand ready
Aug 14, 2015 10:26 PM
