coolant temp fix?
Old May 4, 2004 | 12:22 AM
Akabane's Avatar
coolant temp fix?
are these the symptoms that i should do the copper block weld trick?
car overheats
coolant bubbles
starts up flooded sometimes
smokes
eats gas?
coolant smells like fumes?
thanks!
Old May 4, 2004 | 12:24 AM
Icemark's Avatar
sounds more like you need to rebuild than use a band aid
Old May 4, 2004 | 01:32 AM
mcnannay's Avatar
Lean Mean Speed Thingie
new gasket set for the engine, and don't use the copper block weld...that stuff sucks. do it right and you won't regret it
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Monsterbox
Sep 11, 2015 03:29 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
