Low transition boost
Old May 3, 2004 | 09:49 AM
cruiser's Avatar
I was getting normal 12-8-12 boost pattern during the cold days. But now I'm again getting 12-6-12psi of boost. What could be a cause for such high pressure drop at transition ?
I tried fiddling with the ProfecB balance dial from 11 o'clock position to 4 o'clock position but it doesnt seem to make a difference.
Is there some check valve I should check or something ?
I get about 3psi of boost in neutral when I rev it (which I think indicates no boost leak).
Thanks !
Old May 3, 2004 | 10:04 AM
rynberg's Avatar
Inspect the check valve on the line from the turbos to the pressure chamber.
Old Jul 11, 2004 | 10:49 AM
cruiser's Avatar
How do you inspect the check valve ?
Is this the green/white valve you're talking about that can be accessed without removal of UIM ?
Old Jul 11, 2004 | 02:48 PM
SWAT81's Avatar
8AN5H33
I'm having this problem as well recently I wouid like to know how to check them as well
Old Jul 11, 2004 | 03:18 PM
cruiser's Avatar
I also read it could be a faulty Turbo Control Solenoid. To check that one, you need to take off the UIM, right ?
Check valves I think only allowe boost or vacuum to pass in one direction and not the other.
But how to test the solenoids ?
Btw. where to buy MityVac with pressure/vacuum producing capability online ?
Old Jul 11, 2004 | 03:53 PM
dgeesaman's Avatar
I just ordered the Mityvac Silverline plus. It's about the only Mityvac that does pressure and vacuum out of the box, and I think it also has higher limits for applied vac. and pres. than the other ones.
I have the basic Mityvac and it works fine, but I needed to get an extra pressure gauge to Tee in when doing pressure, and it's more cumbersome this way. PM me in about a week and I'll let you know how they compare.
It's about $60 from a number of places - ebay.com stores, or google for 'silverline plus'.
Dave
Old Jul 11, 2004 | 03:55 PM
dgeesaman's Avatar
I'm also fighting a slow transition and sluggish boost onset. Would a slow CCA be a possible cause?
Old Jul 12, 2004 | 09:59 AM
wrankin's Avatar
Old Rotary Dog
It sounds like you are not prespooling the secondary turbo.
Check the turbo pre-control solenoid. It is one of the pair bolted to the front of the UIM. You should be able to tee a line in there and check for proper operation.
Trace the line to the pre-control actuator on the turbo assembly. Test the actuator with a mighty-vac. Make sure the actuator arm has not come off the lever that controls the gate.
Good luck,
-bill
Queppa
Nov 18, 2024 03:47 AM
rgordon1979
40
Mar 15, 2022 12:04 PM
HDA
Nov 3, 2015 03:49 PM
AXA
Sep 5, 2015 10:06 AM
gabescanlon
Sep 5, 2015 12:09 AM
