whats to much boost (please help)
Old May 1, 2004 | 10:56 PM
superstock2's Avatar
Boss
can i stock turbo II handle almost 12 pounds just for a little bit? has 2.5 bonez race pipe and apex'i gt catback 2.5 rb dp fuel cut defencer and modded tb. please help
Old May 1, 2004 | 11:02 PM
DelSlow's Avatar
Hot Dicken's Cider
not if you dont have an upgraded fuel pump. i doubt it could handle 10 psi with those mods and a stock fuel pump.
Old May 1, 2004 | 11:16 PM
igottafc's Avatar
RX7less **(
12 is the absolute limit for the stock fuel systems.
Old May 2, 2004 | 02:37 AM
Jaared's Avatar
Ahhhhhhhh hhh....
top mount IC dosent cool 12psi very good... hope you live some where it dosent get hot or have red lights....
heat soak is a killer.
Old May 2, 2004 | 09:06 AM
10aeturbo2's Avatar
I'm running 11psi on a t4 with an npr front mount but otherwise everything else is stock. I do have an egt gauge which lets me know if i run lean or not. The leanest my car will go is about 1380 F. I say get an egt and first try 8 psi, Then try 10. Right down how lean it went from 8 then to 10. If its not too bad try 12.
Old May 2, 2004 | 01:04 PM
I ran 1bar on mine for a week or two and all that happened was a blown motor, so other than that it's ok.
Old May 2, 2004 | 01:22 PM
PilotSi's Avatar
Only a blown motor? Cool, I'll try it thanks!
David
Old May 2, 2004 | 01:29 PM
3RotorRocket's Avatar
Don't mess with boost if your basicly stock you will just make more problems.
Old May 2, 2004 | 01:54 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
when adding more boost you MUST add more fuel or engine damage WILL result.
Old May 2, 2004 | 02:07 PM
Jaared's Avatar
Ahhhhhhhh hhh....
making HP have a cost and the cost is fuel. thats just how it is...
btw have any of you ever seen the short video that shows how much fuel a insano pro dragster injects under full throttle? they had a display with a clear cylinger type thing... man it looked like the flood gates opened.
Old May 2, 2004 | 04:58 PM
Boss
i maybe only boosted 11 pounds for less than thirty seconds
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
